Question about Vicks Cool Mist V400 Humidifier
Pickup tube replacement for v400 - Vicks Cool Mist V400 Humidifier
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
The clear plastic drainage tube that runs from our Aprilaire furnace humidifier into the basement floor appears to be clogged with brown gunk. How can we clear this line.
One way of removing the gunk is to disconnect the tubing from the humidifier and use a flexible and thin rod that will fit in the tubing and try to dislodge it, or you can try using a shop vac and see if the suction pressure will remove it. If the tubing is really clogged then sometimes it's better to just replace the vinyl tubing with pvc pipe and drain it to the floor drain, I always prever pvc pipe over vinyl tubing when it comes to drain lines for humidifiers.
Jan 17, 2011 | Aprilaire 700 Humidifier
The humidifier leaves a lot of water on floor , is that normal/
Hi. It looks like more people is complaining about this. It shouldn't happened but I'm think that this is just a big cons of this unit. Return to the shop and buy another one basing on people reviews or use this unit and some rugs
Oct 19, 2009 | Vicks Cool Mist V400 Humidifier
I need to replace a part . Where do I go on line for parts?
dont shoot the messanger but unfortunalty they are not designed to repair. when they break you need to replace. now a whole house duct mounted is diffrent but on the stand alones thats the deal
Sep 06, 2009 | Vicks Cool Mist V400 Humidifier
Loud noise
Try checking the pick up tube that spins from the motor to the resivoir. If this is not seated properly or off balance even just a bit, it can cause your humidifier to sound like a small waterfall. Hope this helps
Aug 01, 2009 | Vicks Cool Mist V400 Humidifier
Hi, I just recently purchased a Vicks Cool Mist Humidifier V400 Series. Could hardly wait to get it working. Problem,it did not come with the filter, box doesn't say not included. I have called around, and...
http://www.filters-now.com/products/uvk.html#UFK04=UVK
here is the website that you need to order the filter. the filter model number is k04. right now i'm seeing the filter as being 5.99 before shipping and handling. if you have any other questions please feel free to let me know.
Apr 19, 2009 | Vicks Cool Mist V400 Humidifier
Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Feb 05, 2009 | Aprilaire 700 Humidifier
Filter
The filter panel may be replaced from the top or bottom but it's less hassle to replace from the bottom because the top tray retains a small amount of water and also because you must be mindful of working around the feed tube assembly. Also, when replacing the filter panel, clean both trays (requires removing both trays, water feed tube and drain tube) and drain tube ... use a 8 water -1 bleach diluted solution or other anti-bacterial solution and wipe the trays and pour some into the removed drain tube (not the feed tube!) and shake it up a bit. Be careful though as you do not want bleach solution getting in your eyes, nor on your skin and clothes!
Jan 21, 2009 | General Filters 1042-LH Humidifier
Vicks 400
YES I DID ICALLED THE # ON THE MACHINE THANK YOU FOR YOUR CONCER LUCY.
Mar 24, 2008 | Vicks Cool Mist V400 Humidifier
Vicks Cool Mist V400 Humidifier Logo
123 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
