Question about Dell SE198WFP LCD Monitor
The display on the Dell SE198 dispays while it is searching for the input mode. It displays for aproximatelly 2-3 seconds while it confirms that it is recieving analog input. Afterwards the motitor "seems" to just go black. The problem I found was that the monitor would just stop shooting light at the display, so one cannot see what is on the display. I don't know what I need to do. Please answer.
    Brigadier General:
  • 10,406 Answers
Turn your computer off.
Turn your computer on, and immediately keep tapping the 'F8' key,
until you see a "boot-menu".
If you never see that menu, connect the monitor to a different computer, e.g., a laptop, and see if the monitor works at all.
When you see the boot-menu, select "Safe Mode".
Reset the video-resolution to 800-by-600, and restart.
Posted on Nov 14, 2009
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
5 seconds, you will have to start step 3 over again.
7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will
increase continuously. Release when the display shows the Stride Length for you.
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
I have the code put it in still not working dont no how to put it in
NOTE: IF YOU TRIED UNSUCCESSFULLY TO ENTER YOUR CODE YOU MAY BE PROHIBITED FROM ANOTHER ATTEMPT FOR UP TO 24 HOURS. See below--section C
A. Input Security Code:
  1. Enter Standby: Press the [SRC] button. Select the "ALL OFF" display.
  2. Enter Menu Mode: Press the [MENU] button for at least 1 second. When "MENU" is displayed, "Security"/"SECURITY" is displayed.
  3. Enter Security Code mode: Press the [|<<] or [>>|] button for at least 1 second. When "ENTER" is displayed, "CODE" is displayed.
  4. Select the digits to enter: Press Press the [|<<] or [>>|] button.
  5. Select the Security Code numbers: Press the [FM] or [AM] button.
  6. Repeat steps 4 and 5, and complete the Security Code.
  7. Confirm the Security Code: Press [>>|] button for at least 3 seconds. When "RE-ENTER" is displayed, "CODE" is displayed.
  8. Do the step 4 through 7 step operation, and reenter the security code. "Approved is displayed and the Security Function activates. However, if you enter a code different from your security code you have to start over from Step 4.
B. After Pressing the Reset button or when removed from power source.
  1. Turn the power ON.
  2. Do the step 4 through 7 operation, and reenter the security code. "APPROVED" is displayed.
C. If an incorrect code is input, "WAITING" is displayed and the input prohibited time shown below is generated. After the input prohibited times lapses, "CODE" is displayed, and input can be done.
1 Time = 0 minutes
2 Times = 5 minutes
3 Times = 1 hour
4 Times = 24 hours
Here's a link to the manual:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MV6521~6021~5021%20(EN).pdf
Apr 23, 2009 | Kenwood KDC-5021 CD Player
Trying to restore os with monitor out.
Hold down the dispay/ext. monitor key in the top row after bootup along with any other function key necessary to change display from laptop display to external display until you snap into the external display.
Reconfigure external display as startup display in My Computer -- Display
reboot to tst reconfiguration.
Apr 06, 2009 | Dell Latitude D600 Notebook
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
1993 MAZDA MX 6 STEREO PROBLEM
If you enter the wrong thing 3 times I think your radio is useless
  • Press SCAN and AUTO.M until bars are displayed.
  • While the bars are displayed, input the code number by pressing the channel preset buttons 1, 2, 3, and 4. Press 1 for the first digit, 2 for the second, 3 for the third, and 4 for the last. If you number is 2547, press 1 three times, 2 six times, 3 five times, and 4 eight times. If the dispay goes off while inputing, begin from step 1.
  • Press SCAN and AUTO.M approximately 2 seconds and 'code' is displayed. 'code' will flash for 5 seconds, then disappear to indicate that the system is operable. If 'Err' appears, begin from step 1.
  • !CAUTION: Three consecutive errors will activate the antitheft system, and the audio unit will be completely inoperable and 'Err' will flash. When this happens, the unit must be replaced by an Authouized Mazda Dealer at the owner's expense. Do not allow unauthorized persons to attempt to input a code number.
    Feb 11, 2009 | OEM Systems Car Audio & Video
    Due to remove the car battery from my car the stereo akking me for code (password) I know what is it, but where is the enter key on the detacheble face
    1 Enter Standby
    Select the "STANDBY" display.
    2 Enter Menu mode
    When "MENU" is displayed, "SECURITY" is
    displayed.
    3 Enter Security Code mode
    Press the Control knob for at least 1 second.
    4 Select the digits to enter
    Push the Control knob to [
    4] or [¢].
    5 Select the Security Code numbers
    Push the Control knob to [FM] or [AM].
    6 Repeat steps 4 and 5, and complete the
    Security Code.
    7 Confirm the Security Code
    Press the Control knob for at least 3 seconds.
    displayed.
    8 Do the step 4 through 7 operation, and
    reenter the Security Code.
    The Security Code function activat
    Good Luck
    Jan 12, 2009 | Kenwood KDC-MP528 CD Player
    Monitor displays properly then screen goes blank
    it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
    Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
    Dell SE198WFP LCD Monitor Logo
    268 people viewed this question
    Alun Cox
