Question about Sony KP-57WS500 57" Rear Projection Television
Picture appears to be in 3-d - Sony KP-57WS500 57" Rear Projection Television
  • 10,594 Answers
If convergence out ICs got defective, TV shows 3D look picture.
Replace convergence out ICs on D Board, these are two big black ICs with similar number mounted on aluminum heat sink, if you are good ij soldering parts in circuit board, then can replace it easily or call local TV tech for replacement.
Let me know further question, if any.
Thanks.
Posted on Nov 14, 2009
I have a no signal prompt on my jvc flat screen, the Verizon fils box is working, how do I fix it?
Make sure you have selected the correct INPUT. Many TVs have several from which to choose. Locate the INPUT or A/V button on the TV or remote. Press it once and wait up to 3 seconds to see if the picture appears. Repeat to cycle slowly through all inputs until picture appears. Some TV / remotes have buttons labeled AV1, AV2, AV3, etc. or similar do go directly to the specific input as opposed to cycling as above. Press each - one at a time - and wait up to 3 seconds for picture to appear.
If unable to display a picture, check A/V cables at cable box and TV. Note which input is being used on the TV for the cable box. Then select the same AV input on the remote that is being used on the cable box.
If still no picture, contact cable company / Verizon for service.
Jun 26, 2013 | Televison & Video
When i go to look at my pictures on my camera it says i have a file error. How do i fix it?
* fisrt try to insert the mmc to the pc,when the mmc folder appeared and no dcim folder appeared try to click the tools and folder options then go to view,check the show hidden files.,if the folder already appeared back up the pictures that detected by your computer to the other folder.,and after you backed it up try to format it.,if the formatting run normal.,then try to format the unit in the menu settings,.after that youll need to insert the mmc again in the tl220 then take 2 to 3 pictures.,if you preview the 3 pictures then remove the mmc to the tl220 then copy the pictures that youd been backed up.
*second if you inserted the mmc and the dcim folder was too none highlighted like the other folder, press he right click go to properties - unchecked the read only and hidden - apply - ok to the sub folders and folder - ok..then reinsert the mmc to the unit.,then preview the pictures.,
Feb 22, 2011 | Samsung DualView TL205 Digital Camera
HOW TO TRANSFER PICTURES FROM MY CAMERA TO WINDOWS COMPUTER?
I understand you?re interested in transferring the pictures from your camera to your computer. Please follow the following steps 1: Connect the camera to the computer using the USB cable, U-8. 2: Turn the camera on 3: A window will automatically appear on your display. Please follow the steps given to you by the programme. If no window appears: 3: Go into my documents 4: Find the location of the camera and your pictures 5 Drag and drop from the camera to the computer
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
Picture appears to be heavy green. Lamp changed
Light Engine/ Call Encompass Parts 1-800-638-3328
Jan 20, 2010 | Televison & Video
I lost my book and i can't remember how to download my pictures from my camera to my computor can you please help me
Jan 06, 2010 | Kodak EasyShare C613 Digital Camera
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
