Question about Kitchen Ranges
I HAVE A GAS STOVE THAT IS PROBABLY 15 YEARS OLD. IT SEEMS TO BAKE FINE, HOWEVER THESE LAST FEW YEARS IT BURNS OR SCORCHES THE BOTTOM BEFORE ITS COMPLETELY DONE. AS I CANNOT AFFORD A NEW STOVE HOW CAN I STOP THIS FROM HAPPENING? WOULD PUTTING A PIECE OF HEAVY DUTY FOIL ON THE BOTTOM OR ON THE RACK KEEP IT FROM GETTING THE BOTTOM TOO HOT?
  • 19,396 Answers
If the bottom element is getting too hot, then either control or the temperature probe is faulty
The temperature probe is located inside the oven cavity. It must be tested removing it from the cavity and reading Ohms with a multimeter set at Rx1.
At room temperature of about 60 - 80 °F (15 -27 °C), the temperature probe must return 1.1KOhms.
Testing the probe at different temperatures is more complex, as you will need a precision oven thermometer, and there are safety concerns involved.
Enter model number on website below, or give us model mumber to locate the probe. The probe is not an expensive part.
If the probe is tested OK, sometimes the control board can be faulty.
If the problem is happening only on lower element, also ensure that the element is not "plugged" because of a contact, in that case the element will stay on all the time.
Here the part site:
Appliance Parts Pros.com Discount Appliance Parts
If part is not listed, try:
Appliance Parts -Research, Repair & Replace.
Or give us the model written on Oven service tag.
Please do not forget to leave feedback.
Regards.
Regards.
Posted on Nov 14, 2009
Gas oven tripping breaker
Get an electrician in, do mess about u could burn the hse down. Wiring probably cann't handle the specialist load.
Aug 26, 2012 | Kenmore Kitchen Ranges
I have a Hotpoint oven that is more than 5 years old, and it burns natural gas. when i use the oven, it will burn, but it doesn't seem to burn all the gas while it is on. The gas company has checked the...
Hello. Thanks for choosing Fixya! First of all you clearly did the right thing by having the gas company come by. Most likely the safety valve on your stove is defective and needs to be replaced. The safety valve is supposed to prevent accidental gas flow.
Here is the other issue. In home repairs have become so pricey once any thing is out of warranty that it is always a judgment call as to what to do. The new gas stoves are much more efficient than the models of 5 years ago, they are much better when it comes to baking with uniform results, etc. etc. etc. There fore, you could call a few appliance repair shops and get estimates, which would allow you to make a more educated decision about whether to repair or replace. Best regards, J.
Nov 13, 2009 | Hotpoint RGB745 Gas Kitchen Range
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Oven goes on off on off on off and it does not get
This is a common symptom caused by a problem with the ERC (Electronic Range Control / Clock). If you can send us the ERC, we can rebuild it for you.
Bruce
www.fixyourboard.com
Aug 09, 2009 | Magic Chef Kitchen Ranges
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Baking part of range not working
If it's electric, it could be the element or the control. If it's gas, it's probably just the bake ignitor. The only expensive of these is the control.
Mar 26, 2009 | Kitchen Ranges
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
