Question about Canon ZR300 Mini DV Digital Camcorder
How can I reset Canon ZR 300 back to the default factory settings?
Please advise the steps to complete the above. I would be very greatfull. Thanks in advance.
2 Suggested Answers
SOURCE: I need sdc 8m 8mb sd Memory card for Canob zr 300. Can't find it.
if you still need it, i'd be happy to offer you mine. almost brand new (canon SD memory card sdc-8m).
Posted on Apr 15, 2011
Rick Riggins
  • 1812 Answers
SOURCE: My playback on the canon
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Posted on Sep 06, 2011
0 characters
1 Points
Thanks for the info. You mentioned factory reset. How does that work?
You should find the reset to factory default option within the camera's menu options.
Try this too: Remove memory card before resetting.
Turn off the camera, and leave the camera without inserting the battery & memory card overnight allowing it to reset.
Dec 10, 2014 | Canon Powershot A1200 12. Megapixel...
Forgot my flip camera security code
  • 1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
  • 2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.
  • 3
  • Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
  • 4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.
    Jun 01, 2012 | Pure Digital Flip Video Camcorder
    My sanyo xacti has stopped recording sound.
    clean the recording head with a little rubbing alcohol on a cotton swab. J.
    Sep 28, 2010 | Sanyo Video Cameras
    The time date stamp no longer displays in my canon zr
    Check if the setting is activated that puts the date stamp on (in the menu) and also check if your time is set.
    Please rate!
    Sep 28, 2009 | Canon ZR85 Mini DV Digital Camcorder
    Same here!
    I believe there is a recall and or update for the ZR 70 contact canon tech support about this
    Jun 05, 2009 | Canon ZR70MC Mini DV Digital Camcorder
    How do i set up my canon zr 90 as a web cam on my mac
    that website let you to make mobile camera as webcame you can search and find zr 90 to make it as wecame
    Apr 29, 2009 | Canon ZR90 Mini DV Digital Camcorder
    Mar 19, 2009 | Canon ZR300 Mini DV Digital Camcorder
    Canon zr 300 won't take tape inside
    FONZIE FIX! It worked for me.
    close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
    Dec 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
    LCD screen is dark with distorted images
    This sounds like the back light has failed. Given that this is only a few months old, I would bring it back for an examination +/or exchange.
    Apr 04, 2008 | Canon GL2 Mini DV Digital Camcorder
    Canon ZR300 Mini DV Digital Camcorder Logo
    147 people viewed this question
    Top Canon Video Cameras Experts
    Sheryl Bahr
    Sheryl Bahr
    Chris Phillips
    Level 1 Expert
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
