Question about Crosley Dryers
My timer does not move - Crosley Dryers
  • 6,784 Answers
HI. This is a defective timer motor. The motor, when energized, is responsible for the forward advancement of the timer dial. If the motor has failed, the advancement will not be possible, thus, rendering the unit inoperable. This damaged timer module must be replaced. Once replaced, the unit will operate correctly.
Posted on Nov 14, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
Moved time pointer on pool timer to set time than read instructions moved pointer back to original spot now timer does not click on or off when it passes pins
Timer brand and model number are not shown.
Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time.
Worn trippers can cause problem.
Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
Intermatic pool timers use set of 156T1978A trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Tork timers use P47 tripper on 24-hour clock dial
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
Paragon 4000 series uses X2772 tripper. Paragon timers are discontinued and trippers hard to find.
Open following links for different timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Paragon-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
Aug 01, 2011 | Hardware & Accessories
Model #t40000r4 pooltimer moved time pointer to change time than read instructions moved pointer back to orginal spot now timer will not click on or off when it pass pins
T40000r4 has one T104 240Volt timer mechanism.
Stationary pointer is pointed at 6:00 position.
Order 156T1978A trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
WHERE CAN I FIND DIRECTIONS TO PROGRAM TIMER #0148373
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 19, 2010 | Hardware & Accessories
Where is the switch that needs to be turned on?
You posted under Woods 59204.
If this is not your timer, add a comment.
Also see Woods timers at following link to identify your timer:
59204 pdf manual:
http://waterheatertimer.org/pdf/Woods-59204.pdf
Image of 59204
http://waterheatertimer.org/images/Woods-59204-image-500.jpg
Image shows switch is located on front of timer, above dial and to the right.
Move switch to left, to Timer ON to operate programming functions.
Move switch to right, to Outlet ON to override timer.
The pdf manual says something different, it says move switch to 'Manual'
Many Woods timers have more than 1 identifying number and pdf manuals are not always current
Dec 03, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
The Cycle selector Knob of 417.42052100 is not moving itself. Machine stays in the washing action without moving automatically to the next one
The timer motor is bad. I am assuming that you can move the timer by hand and access all cycles. Usually this means a whole new timer. You can try to order the motor seperately but it is usually not available alone. The new timer can cost around $100. Why don't you try a used appliance store and see if they will sell you one. The timer motor is fairly standard. The timer itself is not. Just buy a used timer and swap motors.
Jul 05, 2008 | Kenmore Washing Machines
Dryers Logo
71 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
