Question about Dual Electronics CECT P168 Cellular Phone
Im having problems adding music to my i9 phone and subscribing to the internet. How can i fix this????
I tried to download a mms and it said i wasn't subscribed to gprs on my sciphone i9++++
sometimes by playing around with your phone you can ofset the config for internet on your phone call yor service provider and let them help you with that problem
Feb 10, 2010 | Cell Phones
GRPS NOT SUBSCRIBED CAN NOT GO INTO THE INTERNET
You need to subscribe to GPRS with your Service Provider: unlike normal GSM voice services, the charge is based on DATA volume and normally you need to 'agree' to Pay extra for your DATA usage either on a fix quota or on a MB basis as GPRS service is relatively quite expensive.
In any case, call your service provider help desk or consult their website for advise on how to enable the service... if you are a good customer, you can always ask for a 'free' trial for DATA.
Hope it helps: let me know how you go.
Jan 26, 2010 | Dual Electronics CECT P168 Cellular Phone
AT&T internet with the Sciphone I9 3G
Okay, I have solved my own problem. For information on setting up the internet for the Sciphone I9 3G go to http://gr8er1.com/shop/page/2?shop_param= They have tutorials on alot for these phones. Check it out for setting up your internet settings for the I9 3G. I would also recommend having an internet plan as this can get expensive if you do not have one. Good luck.
Sep 23, 2009 | Cell Phones
GPRS no subscribed
go to services, then data account, where you can edit/create a new data account with the correct access point and username/password.
then you can go back to the wap settings and go from there
Jul 26, 2009 | Dual Electronics CECT P168 Cellular Phone
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
I cant get on the internet on my CECT i 9 it keeps saying"GPRS NOT SUBSCRIBED" can u fix it PLEASE:)
Find the i9 network settings at http://chinamanuals.com
Send them your provider and they will come back with the right settings.
Mar 16, 2009 | Dual Electronics CECT P168 Cellular Phone
Internet problems on an cect i9 cell phone.
hey you guys : ) i can the help to fix this problem i called t-mobile customer care
and you have to ask for a tier 3 customer service rep and they send you three text messages that hook up internet and mms call em you will see : ) send me some love later !!!!!
Mar 01, 2009 | Dual Electronics CECT P168 Cellular Phone
Unable to get internet on CECTi9 phone
I have managed to solve the problem myself. I used a site called i9 forum and they have a FAQ section on the internet, which gave a link to a nokia site who then sent the settings to my phone.
Feb 13, 2009 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
110 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
