Question about Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
Samsung SyncMaster 920nw suddenly went black and makes squeaking noises with a slight flicker every few seconds.
  • Samsung Master
  • 1,684 Answers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Jan 18, 2012
    Sergeant:
  • Samsung Expert
  • 406 Answers
This is the problem in the backlight (Lamps).
Kindly approach Authorised service center because this monitor is covered under warranty.
Posted on Nov 29, 2009
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
BuddyMc
Dec 19, 2009 | Samsung SyncMaster 920NW Monitor
Samsung 920nw display stay only one min and off but power on
This is due to backlite problem of LCD panel.
You may approach authorised service center for this issue they will solve your problem. Do not try to do yourself unless you have sufficient experience on LCDS.
Aug 05, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw - Resolution problem
please try to check / use the display adapter device (like nvidia if this is installed in your PC) settings control panel instead of the System->Preference->Screen Resolution option then you can obtain the desired graphics display. best regards
May 16, 2009 | Samsung SyncMaster 920NW Monitor
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
760 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
