Question about Motorola Mobility RAZR V3
How do i turn off the backlight on the front
How do i turn off the backlight on the front screen
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
My env2 is like broken.
the black screen with the rainbow is a clear indicator that you've cracked the internal screen.
Not fixable unless you replace the screen.
Jul 24, 2009 | Verizon Communications enV2 Cellular Phone
My motorola krzr main screen backlight will not turn on.
Take it back too were every you bought it if you broke it yourself they will not help with you with it, If it just did that automatically you have a possibility too get a bran new one
Jun 24, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there.  You may have the backlight turned off.  If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed.  Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
May 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility RAZR V3 Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
