Question about Royal Office Equipment & Supplies
Royal HT550x powers on but does not start shredding when paper is inserted.
  • 1,294 Answers
Change the sensor or clean it,
Posted on Nov 14, 2009
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Jul 21, 2009 | Royal Office Equipment & Supplies
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Unit powers on, but the shredder tines won't run.
If you cant hear the motor running but you hear a click when you insert the paper it sounds like the eyes are ok so its likely the pcb thats defective...give Royal a call at 1-800-524-0799 for parts assistance.
Feb 01, 2009 | Royal 1280MX Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
