Question about Bamix Deluxe Handheld Blender
I can't make meringues with my Bamix - Bamix Deluxe Handheld Blender
I recently burnt out the circuit board for my Bamix M133 stick mixer and thus need to know where I can get a replacement
You could email bamix.com.au. The motors have a 20 year warranty I think. Get a quote before any repairs , as some times replacement is the best option.
Sep 03, 2016 | Bamix Mono M133 White Hand Blender
Bamix needs service. Bought in 1977 with lifelong guarantee. Where do I send it to?
Pearl, link below to Bamix customer service and support.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bamix.com/en/home
Feb 24, 2016 | Bamix Deluxe Handheld Blender
I need attachments
It seems you can no longer buy the HA-3058 or parts for that, however Bamix sells a similar product it seems to be the same machine with only a few aesthetic changes.
They sell many accessories and you can get blades.
Check:
http://www.bamix-blender.co.uk/
I have had our customers buy the Bamix blades for the MegaMix HA3058 and the blades are interchangeable on those machines.
-Colleen@ MendingShed http://www.bamix.com/ http://www.bamix-blender.co.uk/
Apr 06, 2015 | Blenders
Making meringue with hand held bamix
Use the A blade and make sure whatever you are mixing the egg whites in is scrupulously free from any grease etc. Make sure the bowl is clean and dry before you use it.
Best wishes
Sep 20, 2012 | Bamix Deluxe Handheld Blender
How do i change the blades to change function
Website for company: http://www.bamix-usa.com/
Search by model on the site; they have streaming videos that may answer the issue.
May 17, 2011 | Bamix Deluxe Handheld Blender
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
May 21, 2010 | Bamix Deluxe Handheld Blender
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Oct 23, 2009 | Bamix Immersion Handheld Blender
Instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Dec 13, 2008 | Bamix Deluxe Handheld Blender
Bamix De Luxe Hand Mixer - cutter guard
Instructions state to remove it, turn it clockwise, so the opposite remains true. To replace it, turn it counterclockwise.
Nov 21, 2007 | Bamix Blenders
Bamix Deluxe Handheld Blender Logo
429 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Stan Ford
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
