Question about Nintendo Wii Console
I don't have a problem with the consult, I have a problem with the remote. The cursor bounces all over the place. How do I fix this?
  • 127 Answers
The reason is most likely that the signaler on the inside is connected, but is loose and free to move, i would look for a new or used one, since its not really worth repairing
Posted on Nov 15, 2009
The cursor jumps from place to place as I type
This is a known issue in microsoft word. There is no fix as of yet but most people are moving their cursor to the bottom right of the screen after they have clicked where they wish to be typing. hope this helps
Dec 02, 2013 | Computers & Internet
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
Cursor jumps around
Make sure your fingers aren't on the screen. That makes the cursor jump. Even holding the device with your fingers too close to the screen will cause that too.
Feb 15, 2013 | RIM BlackBerry Curve 3G 9300 Cell Phone
Typing and the cursor bounces all over the place DRIVING me MAD!!! I want to disable the touchpad
Scott,
Go into the Control Panel and choose the Mouse option. Look for a setting called "Tap to Click" or something with a similar name. Disable it. This will make it so that when you click the mouse, you actually have to use the buttons, not just tapping once on the touchpad. Also, check your "Touch Check" or similarly named settings. Turn the touch check settings all of the way up - to avoid having the cursor move if you accidentally brush the touchpad with your palm while typing.
If changing those settings does not help with the cursor bouncing, you can try to uninstall and reinstall the device driver. You can re-download the driver for installation here: http://www.samsung.com/us/support/downloads/notebooks/NP-R580-JSB1US
If changing the Control Panel Mouse settings, and reinstalling the driver do not help, then I would try to plug in a USB keyboard to the laptop and see if the cursor jumping also occurs while you are using an external keyboard. If it is resolved when you use an external keyboard, then you will probably need to replace the touchpad on your laptop. If the cursor is still jumping while you type using an external keyboard, then you may need to replace the physical laptop.
My advice if you have to get parts replaced is to take the laptop to a certified technician to do the work.
Hope this helps ya!
Oct 28, 2011 | Samsung R580 Notebook
I need a replacement 27MHz remote control for a Playskool Tonka Bounce Back Racer model #09995. This model has been discontinued. Would another 27MHz remote, with forward & reverse control features...
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
Jul 10, 2011 | Playskool Tonka Bounce Back Racer Remote...
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
Cursor bounces around, doesn't release when highlighting
Does your laptop have a touch pointer within the keypad? This can cause the problem you're experiencing. Did you try turning the track stick off in the touchpad settings?
May 19, 2009 | Computers & Internet
Wii remote cursor does not show on TV
Your remote's infrared receiver is broken. This is why the cursor / hand won't show up on the TV. The + and - buttons operate over bluetooth, which explains why they are still working.
If the remote is under warranty you should send it back to Nintendo to repair. If not, I suggest just buying another remote as it will cost more to repair than replace.
Nov 27, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Cursor bouncing
I have had some similar issues, I find I must wait till my mapping program is fully open and running before I plug in my GPS unit, and the problem doesn't resurface.
Oct 25, 2007 | Microsoft Deluo Universal GPS USB...
Nintendo Wii Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
