Question about KitchenAid KGRC707 Gas Kitchen Range
Stove not heating up
I have changed the gas valve it seem s to be ok then i have to hit it to open then the gas comes through and it works great then next time it will not heat up againtill i tap it again then it works
  • 331 Answers
SOURCE: Valve not opening
Easy fix. Your oven igniter is getting weak. The glowing bar next to the manifold must draw between 2.7 and 3.3 amps before the safety valve will acknowledge that it's actually hot enough to ignite gas and open up. Your igniter is most likely right at ~2.5 amps and the valve is "wanting" to open, but won't without some persuasion (hammer anyone?). The part number for your igniter is 9751123 and is available. Your local appliance parts house may not carry it, but there is a substitute that they WILL carry. Its' part number is WB2x9998. It's a universal flat igniter. Unplug the oven before repairing it, OK?
Posted on Jul 29, 2007
0 characters
1 Points
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Oven will not work
With a gas range, I wouldn't fool with it. Get a service man out there now! Gas stoves are great untill they malfuntion and need a qualified service person to check it out. It's cheep insurance if there is a gas leek causing the problem. The alternitive-------!
May 21, 2009 | Kitchen Ranges
Oven will not heat
ok few things sound like the gas valve may be turned off what i mean about turned off is at the gas valve contro;l normally installed under the stove on the left side of the valve tere is a verry small lever that serve as a shut of vave i have seen those lever in plastic normally red it may have sticked it self close or fallen out check on the floor if you do not see any small parts another thing check for fuse also there is a solenoid valvve that possibly not opening up one more thing does your stove connect to a normall 120 volt plug or does is connect to your 220 volt electric stove plug with a adapter if so check your breakers thanks
Mar 15, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Kenmore gas stove doesn't heat properly in bake mode,takes 2hrs to heat to luke warm. Smell gas when I open door. Works fine in broil mode
the heating element is coroded better to change the heating element first clean the gas valves...
thank you......
Mar 06, 2009 | Kenmore Kitchen Ranges
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Mar 10, 2008 | Amana RanARG7302 Gas Kitchen Range
KitchenAid KGRC707 Gas Kitchen Range Logo
21 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
