Sony DVD player color problem
My sony DVD player has started showing colors in purple and green hues. What could be the problem? Can I resolve it on my own or do I need to take it to the Sony service center?
MY PLAYER WORKS FINE BUT THERE IS NO COLOR .
My Sony DVP-NS72HP is also only showing colors in purple and green primarily. This is a new dvd player (last 3 months or so). I've gone through the manual and reset the dvd to factory settings as well.
  • chewyrolo Nov 22, 2008
    JVC player playing dvds in green and purple hues only.
  • Anonymous Mar 08, 2009
    Our is an older Panasonic-- just started doing the same thing.
3 Suggested Answers
kehalim
  • 55 Answers
SOURCE: Sony DVD player color problem
Safely try playing with the cable connectors on both your dvd and tv end - does it have any influence? if so, try inserting them more firmly or you might have a problem with one of the cords.
Posted on Oct 29, 2007
A few weeks ago my DVD player suddenly started playing everything in black and white. I thought maybe it was the TV because it's old and the DVD player is hooked up to it thru the VCR. But I tried it on another TV and it's still black and white. Everything is plugged in correctly and I didn't change any settings or anything. Can anyone help? Or is it time to get a new DVD player?
Posted on Jan 23, 2010
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
My Sony DVD player is only showing colors in green and purple hues. Could it be a connection problem?
Yes. Could be the color signal jacks in the back. Make sure you have them plugged in properly, green for green, blue for blue, and red for red.
Jan 06, 2011 | Sony Televison & Video
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KDF42A10 COLOR OFF
describe the yellow or green hue, is it eaven all over the screen or does it look like it is more noticeable on some portions of the screen. could be that you might need the light engine repair.
Jan 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Gray margin & not right hue
I just purchased a Sony SLV-798hf VCR secondhand. It did not come with a remote or instructions. Thus I'm unable to set time or use the record function. I tried getting a manual online and was unsucessful.
Aug 02, 2009 | Sony Televison & Video
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Color convergance
The green hue (I had it too) is a result of the optical block failing.
Sony has extended their warranty (regardless of the purchase date). see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Apr 24, 2008 | Sony KDSR50XBR1 50" Projection HDTV
All These units need servicing, They all are having problems with the video output circuit. It could be a coupling capacitor or the video chip itself heating up and distorting the output after short playing periods.This may be a simple fix of changing the output coupling capacitors. But it also may be some internal distortion in the chip. These unit need to be tested on a oscilloscope and check out in the video out input section to look for possible component failures.You should contact a service center that will test your unit and give you an evaluation of the cost effectiveness of a repair. Hope this helps you with your problems.
Oct 29, 2007 | Polaroid 7" Two-Screen Portable DVD Player
Televison & Video Logo
471 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
