Question about Cuisinart Coffee Makers & Espresso Machines
All the water doesn't empty into the pot and the warming plate doesn't work on my dgb - 700bc.
  • Cuisinart Master
  • 19,396 Answers
Hi.
That often happens because thermostat is not working well, as it is covered with limescale.
Try descaling the machine with an apposite product, or using 30%Vinegar and water solution.
If that does not work, then the thermostat may need replacement.
In that case you can call Cuisinart at the number listed on the owner manual to get support.
Regards.
Posted on Nov 14, 2009
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
Overflowing coffee maker
could be using incorrect filters for a different coffee maker, sorry if this sounds obvious but this is the first thing i would think it was unless the water flow is adjustable and coming through quicker than the filter can drain it through
Apr 29, 2013 | Cuisinart Grind and Brew 12-Cup Coffee...
Coffee pot turns off after brewing
This is the correct operation for this type of coffeemaker. It uses the thermal carafe to keep the coffee warm after brewing, and doesn't use power to operate a warming plate
Oct 04, 2011 | Mr. Coffee 8 Cup Thermal Carafe...
My cuisinart grind and brew model dgb-700bc shuts off right before it is done brewing and i am getting coffee grounds in my coffee pot
Too much grounds or not running through fast enough. Right filters? basket flow hole vlesr? Sounds like it's backing up and flooding causing the grounds to get by yje filter. If you dare, **** the hole out just a tad. with the end of a sharp knife. not too much. You can always take out mor. This is called consuner calibration. Good Luck -Ned-
Sep 19, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Pot stops brewing before empty
Hello jearle0249,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, jearle. Positive feedback is appreciated. Good luck. NormanZ
Jul 08, 2009 | Cuisinart DGB-600 Coffee Maker
Coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
