Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
MY IBM_LENOVA- Computer shuts down perodically whther I am working on it or not and then restarts on its own
  • Lenovo Master
  • 19,396 Answers
Hi.
If the laptop is turning off when idle, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling thesystem to exclude system problems, or test the laptop starting OS from cd or staying in Bios settings mode, so to exclude installed system.
If laptop is still shutting down, then problem may be overheating.
Overheating usually happens when the fan is not coming ,therefore when the computer overheats.Or the fan is not cooling enoughand computer is overheating.
Monitor computer temperature using a software check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is wellmounted, if fan has poor contact with CPU surface , cooling will bepoor.
If fan does not come up, and critical temp is not detected, then the sensor on the main board is bad, this is very uncommon. When this happens the problem is usuallyrelated to system or power settings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
Thereare also more than one fan on many laptops, check that one of the fans(CPU fan, video fan) is not completely ded, and therefore cause for theproblem.
By using the software below you can also find out ifthe problem is really overheating. If temperature results within normalrange, then usually it is not overheating.In that case test system andcheck power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Posted on Nov 14, 2009
  • Ginko
    Ginko Nov 14, 2009
    I wanted to add, then when the laptop is restarting instead of turning off, it is often a Windows problem, often caused by viruses that affected computer in the past, or bad software installation that affected the operative system.
    In that case the solution is a Windows reinstall.
    Save all data onto an external disk and do a Windows installation.
    Regards.
I have a laptop i reformat it but my video card is not working i don't know the driver of the video card and the sound card can u help me?
IBM no longer makes laptops, their laptop brand is now known as 'Lenova' and lenova has taken over all their support, all the files for the thinkpad T30 can be found here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-42358.html
hope this was helpful.
May 31, 2011 | IBM ThinkPad T30 2366 Notebook
My ibm laptop keyboard has frozen. All else seems
Please press ctrl+Alt+Del simultaneously and the task manager will be opened up.There you will get the option to shut down.
If the task manager itself is not openeing up then please press and hold the power button for 10 sec and it willlose then you may restart the machine in safe mode and restore it to a previous config.
Thanks.
Jan 06, 2010 | IBM ThinkPad T42p Notebook
When i turn the laptop on it shows a lock and it said to pit in your code but i for got it
hi
here is some simple steps for windows XP's--------password
but do it carefully
  1. Step 1 Shut down or restart your computer. While your computer is booting, press the F8 key repeatedly until the "Boot Menu" appears and you can select "Safe Mode." Once you select "Safe Mode," press "Enter."
  2. Step 2 Click on the "Start" menu and then click "Run."
  3. Step 3 Type "control userpasswords2" in the dialog box that pops up, and then click "OK."
  4. Step 4 Click on the account you forgot the password for and select the reset option.
  5. Step 5 Input a new password into both the "New Password" and "Confirm Password" areas. Select "OK."
hope you successfully do.....
please rate me...
thank you
Sep 19, 2009 | Lenovo ThinkPad X200 Notebook
Boot sequence problem while booting
your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Jul 27, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Solution
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Am asil from india.....my system has got a problem now-a-days.it automatically switch off the system and restart simply....monitor light will blink...and the system will be in off state with two fans...
Hi asil,
Please check whether the fans inside the CPU is correctly working... If it gets stopped the system will automatically ges shut down... Check whether there any wire is stopping the fan...
Apr 21, 2009 | IBM Computers & Internet
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
87 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
