To High tempreture
Hi my computer temp is to high going up so fast
My PC switch off every 30mns
I think that something is wrong with my power supply
I Cute model 400W/ P4
+3.3 V 2.83 V
+5 V 4.97 V
+12 V 11.31 V
Please Help
  • 2 more comments
  • Lukas Kaminski Jan 08, 2008
    ow i forgot when i put computer on ther is something like
  • Lukas Kaminski Jan 09, 2008
    ok ill try clean everything vel...
    I know that i must be very carefull cos i dont wont do enything wrong... :)
    I heard about some paste like termo paste for procesor u can put this and everything can back 2 normal.
    The best one is Arctic Silver 5 did U heard about something like this?
    thank U 4 help
  • Lukas Kaminski Jan 11, 2008
    I must change power supply but i dont know witch one will be good 4 my PC
  • Lukas Kaminski Jan 13, 2008
    Thank U for Help everything is allright now
    Thank You one more time :)
  • 36 Answers
COMPLETELY unplug your computer before attempting this:
You need to remove the computer casing, usually there are screws in the rear of the unit, or some units have the sides that slide off.... Get a can of Air, and some cue-tips, and clean out your fan for both the power supply, your processor, and any other fan inside of the unit... Get rid of all that dust. This should be done maybe once every few months at least. Yes, get rid of ALL the dust... be sure to be careful while doing this, do not want u to damage the computer>.<
There's more if that doesnt work, but I'm not sure how technically sound you are, so I don't want to throw too much at you all at once :-) Lemme kno if that works.
Posted on Jan 09, 2008
  • Chris Mc
    Chris Mc Jan 09, 2008
    Thermo paste is nice to assist in cooling your computer... Tho honestly, if you don't do anything stressful (such as a computer Gamer with high res graphics) you shouldn't need something as such...tho it doesnt hurt to do it if you get down the line, and find cleaning everything out isnt working....For more info about thermal paste(grease, w/e) Here's a link i read through and find pretty reliable.
My boiler keeps getting shut down and the message says "supply too fast". I have to reset the boiler every time that happens. What is wrong?
Either the pump in not running to circulate the heat, or the boiler is going straight into high fire and not modulating correctly.
Jan 06, 2016 | Heating & Cooling
High tempreture
A temp increase over half isn't a worry unless it goes into the red zone. When you say A/C is always on, do you mean you cannot switch it off, or you use it all the time by preference?
Jan 24, 2013 | 1999 Toyota Camry
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
The high tempreture cutout switch trips at least once a day. things to look for?
The high temp switch is bad replace or have it replaced.
Jul 22, 2010 | Water Heaters
No cool 80 supply temp
That is a high suction pressure should be running about 46 psig and head pressure should be amibent temp or outside temp and add 25 to it. that will give you approximate head temp. sounds like you have a dirty condenser I would clean it. Check your amp draw on your compressor if its high then I would check for dirty condenser. You can clean it with a stiff hair brush go up and down do not go sideways because you can damage your fins on the coil. Then take a water hose and wash it out. turn off the power to the unit before cleaning do not clean with compressor running. turn off the breaker box. I hope this helps.
Jul 15, 2010 | Bryant 462AJC021BA Air Conditioner
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Was working fine. started burning ac line fuses and noticed a little smoke. I found a bad light switch going to the ac outlet it was plugged into, which I think has caused this whole problem. removed the...
u have a shorted primary power supply unit on your amp. for linear supply check diodes and capacitors. for smps chek switching transistor or any other switching component. if u have no idea get it repaired by a tech.
Jan 30, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
When the monitor is hooked up it will come on for one second then shut back off. You can see windows open but it shuts off so fast. I checked and changed the cords no help. Is this thing trash?
Usually when a LCD monitor has the problem that yours does, there is something wrong in the high voltage power supply board on the LCD monitor.
It is usually cheaper to replace it than pay for the repair, unless it is under warranty still.
Jan 22, 2010 | Samsung 225BW Monitor
Belinea 10 19 20 power issue
Honestly the power supply uses capacitors to build up the high voltages required to run the monitor display. In all high probability one or more of these are failing and they are discharging to rapidly not allowing enough voltage to the display transformer. It won't come on until voltage is high enough. You're gonna need a new monitor soon, If you can obtain a schematic you can check the voltage drops across the output transformer and replace the faulty component but it is very time consuming and hard to get board components these days for digital supply boards in the states. Sorry I could not be of more assistance.
Mar 29, 2009 | Belinea 19" LCD Monitor
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
