https://www.amazon.ca > Iomega-Prestige-External-repl...
This 12V high-quality power adapter is compatible with the Iomega Prestige 1TB External hard drive. The plug fits a US 2-pin wall power socket. This power ...
Hard Disk Size: 1 TB
Connector type: 2-Pin Rating: 4.2 · 12 reviews · $21.73 · In stock
No, that's not required. Open "My Computer" and then right click on it to find the hard drives listed. If it shows up THERE, and isn't showing when you first plug the USB in, then there's nothing wrong other than the computer just isn't recognizing it as Booted to, or as an external hard drive.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly. I suggest you get a new AC power adapter for this drive.
1. you have a bad power adapter or the electronic controller board in the hard drive case has malfunctioned. 2. You should call the manufacturer for a replacement power adapter or go to the local computer store and purchase a new case for the hard drive.
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the
hard drive via the adapter pack have broken. The serial number is
579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to
know which is the correct product to buy please
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
