Question about Lincoln Electric K1170 AC-225 Stick Welder
I just bought a AC225 stick welder, there are two cables coming out of the machine, I don't know which one is the work cable and which one is the holder cable?
    President:
  • 1,922 Answers
It doesn't matter which one you use because it's alternating current, normally the longer one is your electrode holder cable so you have more cable to move around with,but either way it will work, if it's a D.C. welder then all your doing is using reverse polarity and in some cases welding this type of welding is superior to straight polarity
Posted on Nov 14, 2009
I have a Craftsman Stick Welder mod. 113.20245
http://www.shopyourway.com/manuals/27720 good luck with cables they are discontinued. you may need to go to a welding supply house so they can size the connection
Oct 17, 2015 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I have a older lincoin ac225s welder I got this from a old man that said it worked . well it has no power cord on it and my question is is the ground wire connected to the point where the ground from the...
Hello, I was a little suspicious about the voltage on this unit. Forgive me if I am telling you something you already know on the power side of this welder. http://content.lincolnelectric.com/pdfs/products/literature/e230.pdf
The welder you have is a 230 volt single phase 60 hz. What you require is a 230 volt connection. The two line wires from the 230 are connected on either side of the switch. The ground has to be connected to the chassis / frame of the welder itself. I would not connect to the ground cable output, I would connect only to the metal chassis of the welder. This is to keep the welder isolated from the main power circuits in your shop.
Jan 28, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Electric welder won't start
Hi, double check the leed connections in the handle, these can come loose or the cable may be degrading.
Hope this helps
Jul 27, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Would like online manual
You can download your manual from the Lincoln web site:
http://www.mylincolnelectric.com/Catalog/lecooperatorsmanualsearch.aspx?cnt=0&keyword=ac-225
The picture displayed here isn't a AC225C I don't think, I think that's an S. In any event you can download whatever manual you need.Lotsa luck!
Jun 01, 2010 | Lincoln Electric AC225 Stick Welder K1170
I have a lincoln stick welder . want to know what it's worth
I bought a good working Lincoln 225 about 2 years ago with the extended leads for $ 35.00 at a garage sale
Mar 06, 2010 | Tools & Hardware - Others
Welder Motor runs , Gen works , welder won't excite and weld
A MIG welder is a complicated machine, unlike the stick welder. You can lose a lot of time if you must wait for someone else to fix the MIG. If you know basic troubleshooting for your welding machines, you can save a lot of time and a lot of money.
See if the wire is feeding properly. A worn drive roller can affect the feed and cause it to slip. When you're checking, look for debris and dirt on the liner. This can also cause bird nesting. Sometimes troubleshooting welding machines is as simple as cleaning it and allowing the wire to move freely.
  • Step 2 Look at the tip near the wire exit, inside of the gun. A worn out tip doesn't allow the electricity to efficiently hit and creates a lot more work on the job. Burn back can cause a bad wire.
  • Step 3 Clean the welding cup of the splatter. This task seems mundane, but troubleshooting welding machines usually involves clean components. Proper gas coverage cannot occur if the cup is plugged.
  • Step 4 Inspect the ground clamp. When this part is coated with oxides, electrons can't readily transfer. A bad ground **** can cause a lot of resistance and change the way that the current comes back to the machine.
  • Step 5 Examine the welding cable for worn spots. A badly worn can cause problems.
  • Step 6 Adjust the brake on the wire spool. Setting it too high or too low can cause problems with your machine operation.
  • Sometimes you can overlook the simplest things when you're troubleshooting welding machines, so always go from the simple to the more complex.
  • Always have a qualified electrician look at the parts on the inside of the machine.
  • Don't continually subject your MIG welder to thermal overload, which could cause permanent damage.
  • Oct 27, 2009 | Welding Tools
    Inverter stick welder welding rod sputters and sticks
    It sounds like the rod that you're using is too big. If it is a 110 volt machine, and you're using a 1/8 rod...Then the rod is too big. Try a 3/32 rod.
    Jul 14, 2009 | Welding Tools
    Lincoln Electric K1170 AC-225 Stick Welder Logo
    461 people viewed this question
    Top Lincoln Welding Tools Experts
    Jim Goldsmith
    Jim Goldsmith
    Rob Emerson
    Rob Emerson
    Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
