Question about Whirlpool GEW9250 Electric Dryer
Heats tub will not turn makes a sqeaky noise when comes on
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Problem 1...Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Problem 2...While you have the drum out, you should lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil.
This will possibly solve your noise problem, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 14, 2009
My hp 3500 is making a sqeaky noise before it prints. the page comes our beautifully but the noise is disturbing.
I have found these printers to be noisy at the best of times, but bad cartridges can add another level of noise to things. Squeaky cartridges are not uncommon, particularily if they are remanufactured cartridges and not orignal HP products.
May 04, 2011 | HP Color LaserJet 3500 Printer
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
Sqeaky fan rotation
Try oiling the pull bearings. If you can determine that the noise is in the motor, try nelsonappliance.com. They have replacement motors for your fan for less than $20.
Regards, --WoobieDog--
Jul 10, 2009 | Lakewood 007 Floor / Box Fan
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
May 11, 2009 | Frigidaire Electric Dryer
What is the noise coming from my dryer?
Good Afternoon,
If the shipper has insurance they should replace the dryer. No?
Mar 27, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Washer Model: > LATLAT9457AAM Problem experienced: > High pitch sqeaky noise during spinning (draining) cycle. > Rubber burning smell(from transmission belt?) > Pulleys move OK with...
Most probably the bearings heating, which in turn heats the rubber seals and causes the belt to slip.
If there is no noise of metal on metal, you may be able to grease the bearings to get some more life out of them.
Taking the drum out is not an easy job though.
Jul 07, 2008 | Maytag Washing Machines
LG wm1814cw motor tries to turn but only moves 1/2"
The motor or "stator" as the call it in your machine is bad and needs to be replaced.
Apr 08, 2008 | LG WM1814CW Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
