Question about Microsoft Windows XP Professional for PC
Print spooler error 1075 - Microsoft Windows XP Professional for PC
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 93 Answers
Be VERY careful when editing the registry as one mistake and your system may no longer boot!
To resolve this issue, follow these steps:
  1. Click Start, click Run, type regedit in the Open box, and then click OK.
  2. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesSpooler
  3. Right-click the DependOnService value, and then click Modify.
  4. In the Value data box, delete the event that is mentioned in the "Symptoms" section.
    Note Typically, RPCSS is the only service that is in the DependOnService value.
Hope this helps!
Remote PC Help
Posted on Nov 14, 2009
Print spooler error
open cmd on your computer
first type:
net stop spooler
after that type:
net start spooler
May 22, 2013 | Panasonic DP-8016P Copier
Bizhub 222 spooler error
If you received a spooler error,do this
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Oct 13, 2011 | Konica Minolta Bizhub 222 Black and White...
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
"fatal print spooler error" error message
Completely uninstall the printer driver and install again. If this does not work, there is a corruption in the windows registry or in the print spooler cache files.
For a temporary workaround, disable print spooling. But, if you do, you will need to remember to never close an application you print from until printing is actually finished.
Jun 28, 2009 | Konica Minolta magicolor 5430 DL Laser...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Microsoft Windows XP Professional for PC Logo
113 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
