Question about Nokia N73 Cellular Phone
NOKIA PC SUIT SHOWS MY PHONE VIA BLUETOOTH. BUT WHEN I CONNECT TO THE INTERNET IT SHOWS NO MODEM
If ur bluetooth device is connected in front put it back nd retry
Posted on Nov 14, 2009
Internet connectivity with pc via blue tooth on e72
go to connection settings on ur mobile go to bluetooth try to change if ur phone hs provisions for 'use phone as moderm' bt u can easily use internet if u hav a nokia pc suit and a usb cable.! Pliz let me know if dis ws helpful..
Jul 12, 2012 | Cell Phones
Tip
How to use a mobile phone as modem.
Two methods are there to use your phone as modem
1)you can use your PC suit to use your phone as modem for You need
*USB cable or Bluetooth on your mobile
*PC suit software provide by phone manufacturer(ex:Nokia,Samsung,LG,Sony Ericsson).
To use your phone as modem
*install the PC suit softwareConnect your phone to PC via USB cable(I recommend you to use USB because it's faster)
*Open PC suit and select "Connect to internet"
*if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list now it works.
2)You can use Bluetooth technology to connect to internet (2 methods are there)
For this you need
*Bluetooth on your PC and phone
To connect(in windows OS)
*Click on Bluetooth symbol on task bar
*Select add device select from device which can be connected to your PC list(set your Bluetooth device to visible all mode)
*Add your device to your PC Add completion of the above...
*Again click on Bluetooth symbol on task bar
*Select "show all devices"
*now select your device(one click) at this time 4 options appears on top your devices list
*select connect using>access point
and 2nd method is
*Again click on bluetooth symbol on task bar
*Select "show all devices" *double click on your device
*select connect to internet from the dialog box which appears after selecting the your device
Above options are with respect to Window 7 and Windows related operating system.
Thank you...:)
ANY SUGGESTIONS?
on Jan 30, 2011 | Computers & Internet
My bluetooth is not working properly to connect on my pc internet
My best oppinion is no need to connect the Pc via Bluetooth.Instead of using bluetooth you can use USB cable via Nokia PC Suit.Coz During using bluetooth some interuption might comes When someone switch on their Phone's bluetooth.This may help you .Thanks
Apr 07, 2011 | Nokia 6303 Cell Phone
How to use my samsung wave as a modem
1)you can use your PC suit to use your phone as modem You need PC suit software provide by SAMSUNG
To use your phone as modem *install the pc suit software *Open PC suit and select "Connect too internet" *if its failed you can use manual setting by selecting "Connect to internet">Select access point>select the name of network operator from the access point list(if you did't get your network operators name in the list you need to contact your network operators customer care they provide the access point name you need enter this access point in the manual updation list and try to connect now.....
2)you can use Bluetooth technology to connect to internet For this you need *Bluetooth on your PC and phone
To connect(in windows OS) *Click on Bluetooth symbol on task bar *Select add device select from device which can be connected to your pc list(set your bluetooth device to visible mode) *Add your device to your pc Add completion of the above...
*Again click on bluetooth symbol on task bar *Select "show all devices" *now select your device(one click) at this time 4 options appears on top your devices list *select connect using>access point
and 2nd method is *Again click on bluetooth symbol on task bar *Select "show all devices" *double click on your device *select connect to internet from the dialog box which appears after selecting the your device
Thank you
Jan 29, 2011 | Samsung Cell Phones
I want to run internet in my pc through my nokia3110 phone
use latest nokia PC suit just connect you phone via cable or bluetooth then u can access internet through PC.if u have any problem then mail me@ raj229622@gmail.com
Jan 22, 2011 | Nokia 3110 Cellular Phone
Sir when i am connect my nokia2626 mobile phone to pc via nokia pc suit when it's not work correctly and the main proble is that when i want to connect my pc to internet using my phone then message shows...
Hi!
You have to select the mode of connection.. through blutooth or by usb data cable.
If by blutooth, you have to stable the pairing of the phone and the pc.. You also need to make sure that your phone has already the settings that your phone provider has sent you to access by phone.. If you can access the net from your phone then its ok to surf internet on your pc via phone as your model.
You also will need to set your phone as your modem.. how? go to control panel and select Phone and Modem, there set up the phone as modem.
If this things are done, then go with your pc suit again and try connecting.
If you are trying to connect via usb data cable.. you will need first to install the driver of your cable before you can start pairing your phone to your pc via pc suit.
I hope i gave you a better idea with that.
Much appreciated if you could rate this help. Thanks
May 19, 2010 | Computers & Internet
Connection problem
If you have an N-series nokia phone, you would need a different PC suite. Check on the Nokia website for the software for ur phone. Its a free download
Sep 19, 2009 | Microsoft Windows XP Professional With...
N 72
HI,
firstly install nokia pc suite 7 or above version, connect ur phone via bluetooth or data cable then click on connect to internet option.
u ll see "one touch access" window.enter in setting select ur operator then click on connect.definetly ur mobile ll be connect thrugh internet.
Thanks.
Jun 18, 2009 | Nokia N72 Cellular Phone
How to connect samsung e251 to pc as a internet modem bluetooth
u need to purchase bluetooth doggle nd install software of bluetooth in pc then connect it ur work is done...
Jun 03, 2009 | Samsung SGH-E251 Mobile Phone - Black
Connect internet throough Mobile office
The phone needs to be plugged in to the usb port Via the data cable and set to modem in the phone settings,you will also need the USB modem driver for your phone.You can get it from Nokia.com
Mar 15, 2009 | Nokia 6300 Cellular Phone
Nokia N73 Cellular Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
