I have an eMachine ET1810-03 with a Gateway LCD Monitor HX2000. I cannot get the sound to work. Please help.
  • jsowens7 Nov 14, 2009
    Hello, thanks for your reply. I am running Windows Vista (Home Premium). My volume is turned up.
    Sergeant:
  • 267 Answers
Ok i will need to know what windows opporating system your running. also make sure volume control on your unit is turned up. if it is you will need to reinstall the sound driver.
Posted on Nov 14, 2009
Testimonial: "All fixed...thank you so much! :-)"
Auto adjustment for resolution won't stay at recommended setting
Linda
hello, for some monitors, when change resolutions take seconds to change, automatic, others have to save them. or your signal if analog, HDMI, or digital try to compesate the screen signals,
when use automatic adjustment, the monitor set for the scale designated in your video adapter.(video card)
Carl
Dec 05, 2015 | Gateway HX2000 20" Monitor
How to remove base from gateway hx2000 monitor
You need to find the original instructions for putting the monitor together, or you could accidentally break the base from the monitor if you attempt to remove it the wrong way. Try Google.
Jul 11, 2014 | Gateway HX2000 20" Monitor
Gateway lcd monitor hx2000 hit by lightning how do
Replace the motherboard. It will be cheaper to replace the monitor. If an item of electronic equipment gets hit by over 100,000 volts it is dead, not just having a rest.
Sep 15, 2013 | Computers & Internet
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
How to take apart Getaway HX2000 , How to disassemble it ? please help
remove base using a small screwdriver around 4 inches in on the top push down and toward the front ,(the front bezel comes off it really on there wedge a piece of metal like a blank for a computer card in between the front and back the front will pop off its tough down by the buttons i took the gateway emblem and popped it off and the chrome strip and forced the bottom off with a lot of persuasion it came apart screen lifts right out have fun this ones a bear
Nov 20, 2010 | Gateway HX2000 20" Monitor
I purchased a gateway HD2201 monitor all I see is white screen
Maybe your resolution is not set to the right settings for your new screen, set the resolution and refresh rate lower with the old screen attached and try again with the new screen
Jul 18, 2010 | Gateway HD2201 22" LCD Monitor
Says no signal
Needs to be plugged in to the computer's video card.
and cable must be plugged into the back of the monitor as well.
May 19, 2010 | Gateway HX2000 20" Monitor
Screen goes black but I can see contents if light is shined on it
YES - BUT - Most likely it is due to a bad cable from monitor to computer. or could also be bogus video card. Manufacturers Defects do happen though. I would chekc the cable first. If you got the receipt - Bring it back and get cha a new one!
Mar 01, 2010 | Gateway Computers & Internet
LG LCD MONITOR
What model monitor do you have? You can check out the following:
LCD LG Monitor
Let us know.
Dec 25, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
