I had to replace hard drive in my thinkcenter
I had to replace hard drive in my think center computer by a repairman. He downloaded everything back. But my floppy drive does not work. It does not show up in my computer file, but everything I check says it is loaded and OK. I am a novice about computers.
    Brigadier General:
  • 10,406 Answers
If it worked before the repairman touched it, take it back to the repairman.
* he accidentally disconnected the power and/or data cables from the drive;
* he intentionally disconnected the cables, but forgot to reconnect them, or did not correctly reconnect them;
* he changed a BIOS setting, which "disabled" the device, so that Windows cannot detect that the floppy drive is installed.
Posted on Nov 14, 2009
  • 1,684 Answers
Chances are when the repairman was installing the hard drive that they accidentally unplugged the floppy drive. You will need to contact the repair guy and have them correct the issue.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Lenovo m52 thinkcentre on ubuntu has wireless built in or not?
Have you tried connecting to the internet with a wired connection. It may need to update drivers for your computer. The update option is in the software center I think.
Feb 03, 2014 | Lenovo ThinkCenter M52 PC Desktop
IBM thinkcenter says no os after installing DVD writer
Did you install a SATA or an PATA (IDE) drive?
First check that the data cables are connected to both the hard drive and the motherboard. (I know that I've frequently had the cables come loose from the motherboard on my ThinkCentre 8433 when I work in the case.) Also check that the power cables are firmly connected.
Next make sure that you have no disc in the DVD writer. (Or enter the BIOS by pressing F1 (IIRC) repeatedly on start up. Make sure that the hard drive is the boot disc.) While in the BIOS, you can check if the hard drive is recognized by the motherboard. If you don't see the disc listed, recheck the data and power cables.
If the hard drive was working before you replaced the dvd drive, you may have changed the master/slave assignment on the drives (if they are both IDE). Remove the drives from the computer and check the jumpers. (These will depend on the manufacturer. Use either cable select or master/slave as needed) The boot drive should have the jumper set to master or cable select. In the case of cable select, the boot hard drive should be connected to the black connector. The slave drive goes to the grey connector.
If you connected a SATA drive, try swapping the SATA ports (SATA 0 or SATA1) that has the optical drive connected to it.
The next thing to try requires either the Windows install or upgrade disc for your version of the OS (including the Service Pack) or a third party partition manager/repair utility disc. You'll need to reset the boot order to boot from the optical drive (or press F12 on starting the computer). Use the Recovery Console (for the Windows disc) to find any existing OS installs on your hard drive and attempt to repair the master boot record or boot sector if it still exists on the drive. Please add a comment with your OS for specifics on using the Recovery Console. (I replaced my WinXP with Win7 and the methods are different.)
You may have been unlucky and had the hard drive fail while you were working in the computer. See if the recovery partition (F10 on boot) still works or use your system image (Rescue and Recovery DVDs) will restore your computer to the last backup. Try doing the restore to a new hard drive if the recovery discs don't work.
I hope this helps. Please add a comment with any comments that will help me give more specific assistance for your missing OS.
Aug 09, 2012 | IBM Computers & Internet
Thinkcenter desktop computers usb drivers I have
Firstly, what operating system are you using? Have you tried uninstalling your usb drivers in 'device manager' then reinstalling them? If this does not solve the problem, use your Windows recovery CD in order to reinstall your system files.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Jul 05, 2011 | Lenovo ThinkCenter M52 PC Desktop
I just got a refurb IBM MT-M 8189 E8U It started shutting down on it's own and restarting on it's own . Have any idea's? I reset the bios and it now boots up and shuts down just before...
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Oct 30, 2010 | IBM ThinkCenter S51 (8171Y1A) PC Desktop
IBM ThinkCenter 8187. CD Will not run.
You have to get into setup and select auto for that drive then make sure it is found in bios (setup). Go to IBM support and download manual for your modal you could also update your BIOS from IBM support and downloads.(also make sure drive is set as master) Please rate me mysleuth
Apr 08, 2009 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
Repaced CD Drive Will not work.
Do you have the IDE cable inserted securely? You may also want to check on the back of the cdrom drive and move the jumper to either CS or Master.
Tutorial on changing jumpers:
http://www.tips4pc.com/Articles/Computer%20Troubleshooting/how_to_set_jumper_pin_settings_o.htm
Hp media center - hard disc failure iminent
I am sure that noone wants to tel you thins but when you go the Hard disk failer iminent that was so you woudl shut it down and transfer everything onto another disk. Once it crashes, such as your has, you cannot recover the data w/o very expensive equiptment or costly contracting out the HD for data recover.      About the only thing that you can do now is replace the hard drive, download a   recovery disk from HP,if one is available, for your model, If you have not already made one, and reinstall the software from the disk.
Feb 16, 2009 | Computers & Internet
Bad hard drive back up and replace on evesham ebox
The only thing I can think of is you might hook up the drive as "slave" drive on a working computer and see if it will operate long enough to retrieve your data. But if the drive is dead you may have lost everything that was on it. There are services that do data recovery on dead hard drives but I'm sure it is expensive to have this done. This is why I always back up everything I do to a different device while I am working.
Jan 16, 2009 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Will not load.
my old computer had a problem like this, i think the only way to fix a problem like this would be to reformat your hard drive and reinstall your operating system, which would delete everything on your hard drive...if you do not want to lose the files on your hard drive, you can hook up the hard drive to a different computer as a secondary drive and take the files you need off of it...then put the drive back in the original computer and reformat...after that just put back the files back on the original computer with a flash drive or an external hard drive...
cant think of another way to solve this
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Computers & Internet Logo
David Payne
David Payne
