Question about Yamaha Emx88s Powered PA Mixer System
Run (4) monitors with double female adaptor?
With just one output for monitors, I can only run (2) monitors from this head. How about a double female adaptor off that jack to run (4) 8-0hm monitors?
    President:
  • 1,653 Answers
If you connect the 4 monitors in a cross arrangement ie wire 2 monitors in series with each other and then do the same with the other pair. Effectivley you will then have 2 monitor sets e3ach measuring 16 Ohms each. Then wire the 2 sets in parallel to bring back the overall impeadance to 8 ohms. See the diagram below.
Posted on Nov 14, 2009
Testimonial: "Will give it a try at some point, but was hoping for something less invasive. Thanks!"
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Sep 16, 2011 | Computers & Internet
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
I need an adaptor for my mouse chip to I can plug it in as there aren't enough flat ports on my computer. Where can I obtain one of these?
It sounds like you have run out of USB ports and you need to plug in the reciever side of your wireless mouse. You have 2 options, a USB female to PS2 male adapter, or a ISB "hub". The hub is easiest to find and you can use double stick tape to hold it to your desk or computer case. Runs about $10 at your nearby department store's electronics department.You may also be able to find a USB splitter cable but they are not as easy to find. The USB female to PS2 adapter would have to be ordered as it's not commonplace so stores won't stock it.
Jun 30, 2010 | Microsoft Wireless Mobile Mouse 3000
Looking for new computer that will support 4 monitors.
i may be wron but i'm not aware of any standard pc that will support 4 monitors. I used to run two monitors when i used my pc for djing on but that was down to the garphics card, many better spec cards will support dual monitor output. You could try getting 2 graphics cards that support dual monitors ans running them in SLi mode, that would give you 4 monitor outputs. Have you checked the Nvidia website? it's possible they have software that would support multi monitors.
Nov 21, 2009 | E-Machines eMachines Desktop PC
Gettin feed baq from the subwofer output when Y splitter is attached to feed RCAs to the amp.
use a "y" adaptor on the amplifier inputs instead of the headunit output. In other words run a single rca line from the headunit to the amplifier but connect to a one female into two male y adaptor before connecting to the amplifier
May 20, 2009 | Dual XDVD8181 Car Video Player
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
Installation
take two out puts from your cd player and run them in the inputs of the equalizer and believe me they are going to work.Remember if the outputs from your CD player are of high note (out put)the volume should be kept at minimal to avoid the rumble.
Aug 18, 2008 | Pyramid 10 BAND EQ 300 W WITH LIGHTS Car...
Fails to go to "Setup", does not show on Screen.
1.make sure your monitor is plugged on the video card.
2.check *********** board manual for videocard slots.
3.check your videocard if they nid extra power from four(4) pin
female power cable or six pin female power cable.
4.try using another monitor.. or TV XD
May 09, 2008 | ASUS P5N-E SLI Motherboard
How to connect 2 Amps for my car audio system
Based on your post, you actually have 2 concerns:
1. Power - Normally this is the +12V straight from the battery + terminal. If the existing power wire from the battery to your old amplifier is capable of carrying the combined current (in Amps) of the current + the new, then it is simply running an extension of the B+ line (usually big red wire) from the old amp to the new amp. The negative/ground is simply connecting to the chassis/exposed metal part of the vehicle.
On the other hand, if the old amplifier uses a rather not so big wire to supply it from the battery, you are better running another bigger wire from the same battery terminal to the new amplifier.
You have to check how much current the amp will draw from the battery and select a wire that is capable of carrying that much current without heating up. Offhand a #8 AWG would suffice for most single amp.
2. "Where does the Line cables go?" If you are referring to the Line INputs of your new amp, they maybe connected to the RCA OUTput (line level) of the old amp (it it's got one). Alternately, if the old amp has only INputs and your new amp has both INputs and OUTputs, remove the RCA connection to the old amp and plug them in to the new amp. Thereafter connect another pair of RCA male cables from the output of the new amp to the inputs of the old amp.
If neither of the new or the old amps has an OUTput RCA female, you may need to use a splitter of some sort. Below is an image of a two female RCA to a single RCA male.
You can hook it up in many ways. The simplest would be to remove your existing RCA connection to the old amp, plug in the double female/1male to the INput of your old amp. Connect the cable from the head unit to one of the female RCA. Connect another pair to the other female and the other end to the input of the new amp.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 22, 2007 | Car Audio & Video
Yamaha Emx88s Powered PA Mixer System Logo
215 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
