Question about Bosch Exxcel WVT 2850 Front Load Washer / Dryer
Cleaning the filter / wash cycle not running properly
Hi, I opened up the covering at the bottom rithg hand corner of the machine to clean out the filter. Apart from some water there was really nothing in there. I ahve had the machine for 2 years and it seems strange that there was nothing to clean out. The nachine has stopped working properly now - it fills and starts the cycle but never drains or rinses or spins unless I set it manually to do so. My questions are (1) will cleaning the filter fix this and (2) how do I clean the filter?
Thanks in advance.
  • 264 Answers
You need to put the machine on its front and look under it and you will see a black rubber it gos to the pump and to the drum well the drum one has to come undone with a flat head screw driver and if that's clean then put it back properly when you have done that and you have cleaned the pump out if the machine still done work then your pump has gone you will get one from ebay don't for get to wright down your model number ok good luck
Posted on Jan 08, 2008
  • Jason Harris
    Jason Harris Jan 08, 2008
    if you want me to help you again get back to me
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Hi, I am not able to open the door of my Whirlpool washer dryer AWZ 5140 E after it finishes the cycle. It shows up E13 with ticking noise. There is no water left at this stage and I am able to open the...
E13 is a dispenser error the appliance diagnostic believes the appliance is full of water so won't release the lock first thing to try is the drain filter bottom right hand corner at the front unscrew it clean and refit just be prepared it's likely u will get some water out it when u remove it.
Dec 08, 2013 | Washing Machines
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
Water will not drain away
ensure the filter in the bottom of the machine is clear.
remove the water my hand using a sponge, to remove any opening to ensure
the pump can rotate. (see user manual)
replace and run the rince cycle to see if this has cleared it.
once resolved give the machine a good wash with a cleaning agent
you can place it in and run the machine one time empty.
I hope this was useful.
May 23, 2011 | Dishwashers
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
Won't spin out at end of wash cycle code is OE
Please clean the filter.
Filter is behind the little door located on the front left corner of the unit.
Please read the owners manual for proper cleaning.
If filter is clean the drain pump may have failed.
Jan 16, 2010 | LG WM-1832C Front Load Washer
How do I open the filter on a hotpoint aquarius WF 321 1200 spin washing machine?
there should be a hatch on the front at the bottom right hand corner! open the hatch and you should see something that looks like a dial turn this anti clockwise. if it does not turn you will have to apply pressure. this could possibly break the componant! don't worry this often happens they are easily replaced from your local domestic appliance repair centre
Oct 16, 2009 | Washing Machines
Bosch WFL 2860 Stops Part Way through Its Cycle
When a machine stops during its rinse period, it is normally a block in your outlet filter. And you say it has not been maintained in any way for 5 years; at least you shd be doing the minimum maintainance like clearing your outlet filter.
Front bottom right, is where access to the filter normally is; get to it and clean out, plug off the wall first. The large plastic is to be turned anti-clockwise to remove, refit carefully after cleaning.
Nov 25, 2007 | Washing Machines
Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
199 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
