Question about Samsung Behold Cell Phone
I have moisture under my touch screen, my phone still works but non responsive to touch
Left phone in rain for 20 min. Very little moisture in phone and water marks untouched, but touch screen non responsive. Hard reset had no effect.
A phone in the rain for 20 mins is way more than enough time for it to get water inside. There still may be hope, but odds are against it. Turn it off now and take the battery out. Get a hair dryer and blow dry it for about 20 or 30 minutes. Don't over heat it, but keep it consistently hot the whole time. Let it cool and try it again. There is normally a white dot somewhere under the battery. If that dot has turned red, you definitely have water damage that voids any warranty you may have had. Good luck with the dryer.
Sep 03, 2015 | Cell Phones
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Cell Phones
Dropped my droid in water. Removed battery, tried to dry it, and it seemed to work but still had some moisture behind display. Removed battery and let it "bake" for 2 more hours at about 110...
You baked your phone at 110°? That may have fried some of the internal circuitry.
The best way to draw the moisture out of a phone is to place it in a container with some rice overnight.
Jan 29, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My VUs screen is non responsive or enters a different key when one is pushed. how can i callibrate the phone
Touch Screen Settings
1. Tap Menu , Settings , then Touch Settings to
adjust the touch screen’s sound and vibration.
2. If the touch screen is not responding as you expect,
calibrate the screen for touch accuracy.
If this does not work the phone has a restore feature, but you would have to back up everything you put on the phone so you don't lose it.
In the menu there is a master reset.
If this does not work contact the company and see how to send in for repair.
There is no software update for this phone at the moment.
Feb 10, 2010 | LG Vu CU920 Cellular Phone
Moisture from hot tub got under the touch screen of my cell phone, and now it's not responsive to touch. Is there anything I can do?
When most cell phones get wet or aquire moisture the circuit boards on the inside rust as they dry out so if the phone is insured I woudl just suggest replacing it because the rust on the inside will continue to affect the phone even after it is dried out. Depending on who your carrier is you maybe able to have a tech open up the phone and clean the circuit board with some solution. This is not something you should attempt your self because it would void any warrenity remaining on your phone. If you have a warrenity and you phone is not visibly wet and all your indicator on your phone are still negative for water damage (stickers located on or around your battery to show that your phone has water or moisture damage) then just take it in for a replacement but, leave out the part about moisture just tell them the touch screen is not responding
Nov 30, 2009 | Samsung Behold Cell Phone
Touch screen on lg voyager stopped working
Does it have an after market plastic cover? If so they sometimes touch one part of the screen making it non responsive. On a day it does work try recalibrating the screen.
Sep 08, 2009 | LG VOYAGER VX10000 Cellular Phone
Non responsive touch screen on iphone
i guess ull jus have to replace the screen
Dec 08, 2008 | Apple iPhone Smartphone
If a hard reset (press menu and center button together for 5 sec) and software restore doesn't cure it , you have a broken digitizer of your iPhone screen assembly. There is an iphone repair guide website that shows you how to do the replacement yourself and a third party iphone repair company that can do it for you.
LG KU990, touchscreen not responsible or not recognise
i have the same problem. i opened up my phone and saw a tiny chip thing right behind the screen fried. im thinking it happened because moisture got into the phone. moisture gets into your phone when you take a shower and leave your phone on the sink or something.
Jun 04, 2008 | LG KU990 Viewty
Samsung Behold  Cell Phone Logo
427 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
