Question about Mitsubishi WS-55809 55" Rear Projection Television
Stk392-110 chip is in my tv. can I use stk392-150 instead?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The model number you indicated: WS-55809 does not use the STK-392-110--IT USES TWO STK-392-570 CHIPS.
IF WHATEVER SET YOU HAVE USES A STK-392-110 YOU CAN USE THE STK-392-150 TO REPLACE IT--it is a higher current device than the 110 chip---there are some others even stouter but some create more problems.
I have used the 150 chip on several sets for the 110.
If this information helps you rate this solution as I do this here for FREE.
SD TECH.
Posted on Nov 15, 2009
Testimonial: "That was very helpful info.Will use chips. couldnt make up my mind if safe to use. Thanks a million. "
3 Suggested Answers
SOURCE: stk392-110 chip replacement
stk392-110/150/180 all have same fit, form function except the 150's and 180's are basically upgrades for they're more stable (more heat tolerant than the original 110's); I'd buy the 150/180 myself; you can get the stk392-180 for just under 10 bucks on eletronix.com.
Posted on Apr 20, 2008
SOURCE: Hitachi 51G500A Convergence Problem
I have no experience at tv repair but I solved this problem and you can too. I bought 2 stk 392-150 chips made by sanyo on ebay for $30. I bought a low life jewelers loupe which is a sort of cap with different lens pieces out on the end of the bill for $10 on ebay. I bought a soldering iron and the smallest diameter silver solder and a little suction bulb and heat sink grease from radio shack for $20.
Take the back off tv. Locate circuit board with ics. remove screws that hold board . there are several wire bridges, snap these apart also. number connections with marker, undo connections. you will note that this board is connected to 3 crts by cable, do not disconnect this cable! This board must remain connected to crts by this cable! (so much for tv repair.com telling you how easy you can remove the board and solder it in your workshop) this board must remain connected to the crts, you can flip the board upside
down but all work must be done at back of tv
undo screws on ics. pry ics loose from heatsink. put on jewlwers loupe then turn board over and heat up each ic pin then **** molten solder into suction bulb. each ic has 19 pins. remove old ruined ics ( shame on Hitachi) my tv was only 3 years old! Put gob of heatsink grease on new ic, spread with razor blade, not to thick or thin, stick new ic thru holes in board and screw to heatsink . solder all pins to circuit board. look at the resistors that are close to the ics. if one is burned black it will have to be replaced, they act as circuit breakers and will burn out to protect other parts of the tv. usually the resistors are fine it was just the cheapshit hitachi ics that were bad.
Put everything back together and turn on tv for 20 min. after 20 min do the magic focus. your tv should focus up and be good as new. I have fixed several hitachi 51g500a in this way. Good luck!
Posted on Sep 21, 2009
I have a big screen tv and little tiny white specks are starting to come behind the screen. What is causing this?
There is a fault with the light engine.one of the chips in it is faulty .there is a you tube video showing the fix.unfortunately the chips cost around 150 pound.
Oct 19, 2014 | MITSUBISHI DIGITAL ELECTRONICS MITSUBISHI...
Manual for Magnovox tv
a 32 " tv is under 150 new now
the board to fix it will cost 85 to 120 and your labor.
if its not the input cap chips on the input then its the video chip / whole module
take it some where an try again the environment might magically fix it.
did you switch to hdmi on the menu 1st. an power it up saved.
Jul 25, 2014 | Magnavox 32MF301B/F7 32 in. LCD TV
42LH90
How long have you had your LG TV? LG had a problem with a chip on the main board in the fall of 2012. Most units have failed by now, but if you only watch your TV occasionally, this could be the problem. The symptom is this: Plug TV in, red LED on front lights up. Try to turn it on, red LED goes out and stays out (should flash and turn blue). Hope this helps. BTW, if it is the chip, and you're handy with a soldering iron, you can buy a new chip online for less than 20 bucks and install it yourself. A main board (with the fixed chip) is about $150.
Feb 10, 2014 | LG 42LH90 42 in. HDTV LCD TV
I am seeing blue shadows on my screen while watching the tv
If model number is correct the two stk-392-110 or -150 chips are both going to have to be replaced.
Both are the same part but the 150 is a higher rated part for current.
Dec 23, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Sony KP53S76 Projection TV Convergence IC Bad
Should be a 392-150 make sure you replace both.
Feb 15, 2010 | Televison & Video
TV MAKING A CHERPING OR CRICKET SOUND AFTER IT IS TURNED ON
Two main common failures for these sets is the convergence amps and the flyback transformer (which is rather expensive). Both can make the set "chirp".
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
More solutions => http://www.fixya.com/tags/chirping_noise
Jan 01, 2009 | Philips Magnavox 51MP392H Rear Projection...
Stk392-110 chip replacement
Mar 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
CONVERGENCE Problem cannot adjust ( green gun )
Compare your rgb voltages and your cathode voltages(green, red, blue) and also access your service mode settings. It might not be the STK-392-150 that is defective.
Sep 26, 2007 | Sony KP-43T90 43" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
552 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
