Question about Panasonic PT-60LCX64 Television
Where to find the lamp on the tv - Panasonic PT-60LCX64 Television
  • 4 Answers
Remove the center panel, on the front of the TV, next to control buttons. The rest is simple, although you will need a long neck philipswhere to find the lamp on the tv - 2_bing.gif screwdriver to get to the bulb once get the housing out. The screws are inside the housing.
Posted on May 04, 2010
  • 11,361 Answers
Lamp unit Type: Y67-LMB The Lamp Burnt
If You are look to buy one Try TV Repair Kits.Com
Aug 19, 2011 | Toshiba 50HM66 52" Television
Tv on my samsung p4663w/hl does not turn on. lamp light flashes on front of tv picture does not work. no sound , bulb has no marks on it to show that it is bad
Tv projection lamp have a life span like any other bulbs light sources.Tipically life spans of these tvs projection lamps are around 20,000 hrs of useages.That average out like about 1 1/2 or 2 years and around 4 or 5 hours of the tv is on and watching it everyday.Now the front tv bazel frame of the tv.The word "LAMP" LED light indication is on or flashing are indication of the tv projection lamp life span are over and the tv must have it projection lamp to be replacement to another tv projection lamp.Projection Lamp fillerments tipically dies out when it reaches it life span.Mark or burns on the projection Lamp,will not show or be there,if the tv projection lamp run it natural life span cycles.
Aug 03, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My tv won't turn on. the power supply is good but the lamp light keeps blinking. Does this mean i need a new lamp
Yes,if the tv LED light indication the word "LAMP" on the tv bazel frame is lighting up or blinking.The tv old projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and used daily 4 or 5 everydays?Yes,than ur tv projection lamp life are ended.Yes,than ur tv need a new projection lamp.
Apr 26, 2011 | Samsung HL61A650 TV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
Set turns on then turns off a few seconds later
Set have the tv projection lamp problems.Tv have a "LAMP"LED light indication on the tv front screen panel are flashing are staying on lite?Yes,than the tv projection lamp life are ending.Tv have been on and used like 4 or 5 hours a day and the tv projection lamp been on the tv like a 1 1/2 or 2 years?If it is a new tv projection lamp,than ur tv might have a problem with a board call a Ballast board.This Ballast board job are to help to ignite the tv projection lamp.
Dec 06, 2010 | JVC HD-61FH96 61" Rear Projection HDTV
New lamp is placed in tv, but tv won't come on. Light in front of power button is blinking green, then blinks red. Not sure what the problem is
One question, why you decided to replace lamp in tv? Did tv showed red lamp light blinking?
Suggestion, make sure lamp cover has been placed back in its position after lamp replacement, lamp cover is first thing that you removed from tv cabinet to take out lamp.
Oct 05, 2010 | Sony XL-5100 Projector Lamp for Grand WEGA...
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic PT-60LCX64 Television Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
