My laptop keeps shutting down after its turned on for a few minutes.What's up with that?
  • kjart527 Nov 14, 2009
    Much thanks for the info.I was thinking it could be an overheating problem too.
  • 19,396 Answers
Hi. If computer turns off only when idle, then check power saving settings, accessible from control panel. If laptop turns off while you are using it instead, try first reinstalling the system to exclude system problems, or test the laptop starting OS from cd or staying in Bios settings mode, so to exclude installed system. If laptop is still shutting down, then problem may be overheating. Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating. Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical. If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor. If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settings , rather than overheating. If fan does not come up and temp is critical, then fan is faulty, replace it. There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem. By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test system and check power saving settings. Here is the software to control your fan and temp. sensor state: Download SpeedFan - Access temperature sensor in your computer Download SpeedFan 4.38 SpeedFan - Free software download Do not forget to leave feedback. Regards.
Posted on Nov 14, 2009
System shuts down automatically
Turn on Laptop with F8 key or Delete key -
leave the computer on on the bios mode for few Minutes - see whether system turning itself of -
IF NOT - reinstall the OS
IF Yes - check the Hardware -
May 20, 2010 | Toshiba Satellite M35X-S149 Notebook
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
Hi
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Sony Vaio will not turn on
plz check the powersupply unit , ram
Jun 22, 2009 | Sony VAIO PCG-K23 Notebook
Will not log off or shut down properly
sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
May 28, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Laptop keeps shutting down, both fans not working
sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
May 25, 2008 | Dell Latitude C640 Notebook
My rt2280
the quick answer is turn it off from the power button, then press the dvd button or whatever button you are using.Do it twice if it needs it.
Mar 13, 2008 | RCA RT2250 System
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
