Question about General Electric Profile PP945 30 in. Electric Cooktop
How to install a 208v outlet for a stove
How to install a 208v outlet from a 200 amp 2 phase household panel.
    President:
  • General Elec... Master
  • 1,922 Answers
If its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Posted on Nov 14, 2009
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Electric cook top only gets 120 instead of 240V
see the diagram and fix it. You have lost 1 phase open the outlet wall and measure the phase, go to the main panel breaker open the circuit, and repair the phase, if you are NOT shure call some electrician.
God bless you
Sep 24, 2012 | Jenn-Air 35 in. JEC8536A Electric Cooktop
I need the wiring diagram and plug/receptacle specs for kenmore electric cooktp 42732
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
Apr 07, 2010 | Kenmore 30 in.42731 / 42739 / 42734 /...
My house wires from the electic stove top has 3 wires and my new bosch electric top has 4 on red, white, green, yellow?
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
Nov 15, 2009 | Bosch 30 in. NET7452UC Electric Cooktop
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
General Electric Profile PP945 30 in. Electric Cooktop Logo
990 people viewed this question
Top General Electric Cooktops Experts
gbob59
ray gallant
Are you a General Electric Cooktop Expert? Answer questions, earn points and help others
