Question about Electrical Supplies
Perkins 7.5 gen. I am getting oil in the water ,
Perkins 7.5 gen. I am getting oil in the water , but no water in the oil . What would that be ?
    President:
  • 1,922 Answers
Your water jacket in the block has a pin hole in the block and the pressure of the oil versus the water is higher and forcing oil into the water you need to put dye into the oil and water and trace the leak,then "magnaflux" the block and repair it
Posted on Nov 14, 2009
How to download ecm software for perkins engine DSE 404D.22 made in UK
my name is christian i m a gen technican based in abuja . pls i need some soft ware to repaire gen
Mar 04, 2014 | Miller 907175 Welder Generator Perkins...
ELECTRICITY PRESENTS BUT GENERATOR START IN AUTO MODE
You have the remote control wires incorrectly connected either at the ATS or on the generator control panel, disconenct from both ends and ohm them to make sure they are not shorted between. Then reconnect them at the generator end only. Then join them together manually, of the gen starts and stops when taken apart, the problem is in the transer switch, or incorrect terminated
Jun 14, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Perkins engine
check for fuel blockage or water in the filter. try bleeding air out of the system
Jun 03, 2013 | Diesel Jlg Aerial Work Platform S2 Liftlux...
Genset does not start , alarm can't reset
what safety caused the alarm. if you cant restart it, it may be cause the problem that originally shut the engine down has not been fixed, it could be water level, low oil, high water temp, low fuel,over voltage, all of the above are probably run through the safeties. over volt, and water temp would probably clear its self after it sat a while. try turning off power to panel. for a couple minutes and see if it will reset, if not check water level. and oil levels
Aug 12, 2011 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
May 24, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
500kva 380 volt diesel generetor
make sure gen isnt stopt on protection overtemperature or oil level or coolant level. try to bridge protections one by one to find the course. first make sure all fluids are on level and coolers are clean. fanbelt tension and coolantthermostat can also be wrong.
Jan 23, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Frequent top up and low oil pressure guage.
if the oil need frequent topping up it can only dissapear in 2 ways a leak or the engine is very worn and is burning it.
a worn engine is also a cause for oil presssure dropping once the engine has warmed up probably worn main and big end bearings on the crankshaft as you will know oil is thicker when cold so oil pressure is increased
Nov 18, 2009 | Electrical Supplies
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Electrical Supplies Logo
247 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
