Question about Kenmore Kitchen Ranges
When I use my gas range it smells like lighter fluid. Only when it is on, when off the odor goes away. It is a dual stove with electric oven and gas top. It started with one burner and now all 5 of them stink. It is not a gas smell and it is not leaking.
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Posted on Sep 14, 2010
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
Rotting fish smell coming from back of range (not inside oven)
My husband wouldn't let let up n had to figure where smell was coming from.he took the top of stove off n the knobs.the was me droppings on the fiber layer under the top of stove so he started vacuuming it n then stuck the hose down under the fiber n into the actually stove part...well their was a dead mouse bc he sucked it up in the vacuum.ewe!! We were glad bc the mystery was solved but not glad that their was a dead mouse where we cook.hope this helps u
Feb 26, 2012 | Kenmore Kitchen Ranges
WE SHUT OFF THE GAS TO THIS STOVE SEVERAL WEEKS AGO AND ARE READY TO RELIGHT THE STOVE NOW. WE CAN NOT FIND THE MANUAL AS TO HOW TO DO THAT. WE ARE CONCERNED MAINLY ABOUT THE OVEN AS IT SAYS IT IS A...
You should be able to just open the gas ****. That will supply gas to the gas to the stove. Once you've opened the gas ****, wait about 60 seconds and turn on one of the burners. The electric ignition should work to ignite the gas and you'll have your flame. If you smell a strong odor of gas, DO NOT use the electric ignition until the gas odor diminishes. In other words, when you first smell gas, you can try lighting it. If the smell of gas becomes strong, you DO NOT want to light anything in the area because an accumulation of gas can lead to an explosion. Be very careful.
If this helps, please come back to Fixya and rate my suggestion.
Jun 10, 2011 | Kitchen Ranges
I have a kenmore elite slide in range. we notice the smell of gas
There could be a couple things that would cause your symptoms, I will do my best to try and explain each one.
First off I am assuming from your dialog that everything is cooking the same on the top and in the oven, the times are the same the flames on the top burners look or sound no different. If this is the case the repair outside would not have a direct bearing on a 'problem' but it could cause the odor. Here is why...
Natural gas has no odor a chemical called Mercaptan is added to the gas to make a leak easier to detect. The amount of Mercaptan is regulated closely so it all is consumed in the flame. If there is too much you will get an odor from the flame.
The Mercaptan can line the inside of the piping that feeds gas from the regulator to the range. Working on the pipes can break loose some residue that may have a stronger presence of odorant causing you to smell it for some time. It will eventually go away.
The second thing that could cause this odor is if you have done any remodeling in the home, paint fumes, stains, oils many other chemicals can mix with the gas and cause this Mercaptan to not be burned up all the way and create an odor.
I hope this helps
May 21, 2010 | Kenmore Kitchen Ranges
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Weird smell first use
STOP YOU MAY HAVE A GAS LEAK!!
DO NOT TURN IT ON AGAIN TILL YOU HAVE SERVICE OR CALL THE GAS COMPANY AND THEY WILL COME OUT RIGHT AWAY TO CHECK IT!
SMELL GAS ALWAYS CALL THE GAS CO.FIRST THING!
GOD FORBID!!
Neil
Please give me a solution rating here at fixya.com
Mar 29, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
1,099 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
