Question about Ovens
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Teba electric oven not heating up could it be timer .? Or element? Where can I get a free manual
Posted on Jul 01, 2011
    Sergeant:
    Champion:
  • 215 Answers
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Posted on Nov 15, 2009
Kitchenaid Superba 27 built-in Microwave/Oven
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Apr 02, 2008 | KitchenAid 27 in. Built-in...
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
Oven always switching itself off
Thermal overload has failed. This is a sensor usually with 2-3 wires attached
Oct 19, 2017 | Hotpoint Ovens
Hi I have an Ignis built in oven model number- AKL907/WH which is now displaying "- - - c" and t won't let me press any buttons to correct it, the oven itself does not turn on, any suggestions please? No...
Sounds like a bad electronic control board. Proper replacement might require a service tech. TRY resetting by unplugging it from the wall. Give it a few minutes, then re-plug. Also look for any sort of reset, switch, lever or button.
Dec 15, 2013 | Ovens
STOVES 900GDO USER MANUAL NEEDED
Good luck, and im being sincere, unless you find someone with exact stove to help you i didnt see a single thing for a manual online.
If you can make the timer function, a standard digital timer can have up to 4 numbers.. and when you punch in numbers it goes from right to left.. my stove for instance.. the very first number is minutes. so even if it says 0005, that could be 5 minutes not seconds, and my oven, you dont press anything to start timer, you just put it to required minutes and it starts itself lol.......maybe this provided some insight?
Nov 01, 2013 | Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
Ovens Logo
970 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
