Question about Canon imageRUNNER 5020 Copier
5020i error code E000001-0000
Would you please tell me how to fix this error code? The copier says to turn off the main power switch. I did that, but am still receiving the error code. Thanks!!!
  • chinhill Mar 01, 2008
    I meet the same problem.
    6020i error code E000001-0000, it is no useful to clear this err in sevice mode.
  • Anonymous Dec 07, 2008
    features for IR 5020i
Turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Posted on Jan 12, 2008
Posted on Oct 17, 2012
Error code C3B02
Turn off the machine using main power switch not the one on the control panel. But make sure the on the control panel switch is on. Now hold down the utility/counter button and turn the main power switch on hold down to you see trouble reset touch it power off WAIT TEN SECONDS power on if code comes back DO NOT RESET it means the Fuser Electro-magnetic current amp and or coil is bad reset again it may catch on fire ruining a perfectly good day!!! Get a tech out to look at it
Jul 10, 2014 | Konica Minolta Bizhub C452 Copier
The waste toner bottle is on the right side of the copier by the main power switch. There are two screws that hold the cover on, the cover is the whole one piece below the power switch. Take the two screws out and take the cover off. The waste container is a big milky white container. Pull it out and carefully dump it out and reinstall it and put the cover back on. You will have to go into service mode and reset the counter for it. Good Luck
Jul 31, 2010 | Canon imageRUNNER 5020i Copier
How to clear error code c 3421 on konica bizhub c253
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
May 19, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Canon imageRUNNER 5020 Copier Logo
1,955 people viewed this question
old marine
old marine
