Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washine machine ERROR F5 machine blocked
Cannot resolve error message F5 says, say that the machine is blocked ? Have tried the instructions on the LCD, switch on an off !!
Can not now open the door either.
Any help would be appreciated
    President:
  • 1,653 Answers
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood. Alternatively bale out the sump under the main screen filter plate.
  3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked or restricted.
  4. Also check that the main waste drain pipe and one way valve to a sink waste connection if you use one, is not blocked and clean if required.
  5. Access the pump from under the lower rotor arm and protective grille and check that the impeller is free to move and is not clogged or restricted by debris or sludge. Clean as required.
  6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power. It is a good idea to take digital pictures of the pump assembly before attempting to work on it or remove it so that you can refer back to it when you reassemble the unit or replace it with a new unit at a later date / time.
8. Remove and check the electrical connections to the pump and make sure they are in good order.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage. If they are then clean them thoroughly.
10. Then remove the pump and check motor is OK and that the motor turns OK. Also check that the pump impeller vanes are in good order and not blocked. If necessary replace the pump with a new and identical unit.
11. Carefully reassemble the pump observing the correct placement of gaskets, seals, O Rings, hoses and securing straps, electrical wiring.
12. Reconnect the hoses and then reconnect power and switch the machine on.
Also see additional info to follow.
Posted on Nov 14, 2009
Hotpoint f5 machine is block
Possible fault with the controller unit
Check this link for tips to probe: controller unit
Nov 20, 2013 | Washing Machines
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius stopped working full of washing F5 showing on screen
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
Jan 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
E05 error on hotpoint ultima wasing machine
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudamentary understanding of the mechanics of a washine machine.
Hope this helps, thanks for using fixya
Jul 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
Error code f5
I think you mean error F05 for a Hotpoint washer.
it means the pressure switch is jammed on full, check pump is working o/k and if there is a filter, remove and clean it, see user instructions..
If still no joy, then you will have to call an engineer..
Plz rate this solution.
Thanks.
Jan 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing machine error 14
check for blocked sump hose filter, this should resolve problem
Oct 15, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
3,020 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
