Question about Amana ACF4225AS Electric Kitchen Range
What type of light bulb?
What type of light bulb do i put in the oven?
  • 5,911 Answers
For the model range you have this question listed under, it uses a 40 watt clear applaince bulb that you can purchase at any hardware store. If you wish to order on line, you can purchase a bThe part number is 8009 if you wish to order on line
Posted on Nov 14, 2009
Testimonial: "Thank you so much. Now I will be able to see what I'm cooking."
  • Jeff Rockwell
    Jeff Rockwell Nov 14, 2009
  • Jeff Rockwell
    Oops! Something screwed up when posting...if you wish to purchase on line, you can find it at any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    The part number is 8009 and costs about $3 - $5.
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
Why did oven light explode
It may have been defective or the wrong type of bulb was installed. Only certain types of bulbs are rated for oven use.
Mar 21, 2015 | De Dietrich Ovens
Is the light cover screwed or a push fit NEFF oven
are you sure its not a
Neff H5642N0GB why you wanting off? has the bulb gone? you can take the hole top off to get to the bulb, make sue you unplug it...not just switch it off ! i mean unplug it from the wall !
Oct 06, 2014 | Neff H5642 Convection / Microwave Oven
Replacement light for ""J b968s" ge oven
Remove the lamp and determine what type it is. Take it to a retail store that stocks replacement appliance lamps or an appliance parts supplier and purchase a replacement. Install the replacement lamp.
Dec 01, 2013 | Ovens
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
Ge microwave oven jes1288 light bulb replacement
The light bulb assembly (bulb and socket are all one piece) is part number
WB36X951.
It is located on the air duct assembly where the door switches are mounted.
You can see an exploded view diagram here.
You'll need to remove the outer cover (wrapper) to get to the bulb assembly.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
If you're not able to find the bulb assembly at your local appliance parts store, you can order one here.
Jan 21, 2009 | GE JVM1631 Microwave Oven
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Changing the light bulb in the oven
the light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
Apr 21, 2007 | Stoves Premier 720GRa Gas Double Oven
Amana ACF4225AS Electric Kitchen Range Logo
196 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
