Question about Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
Olevia Hi Def tv 242TFHD, won't turn on. Power cord in good outlet, back power swith to on mode, no lite, no sound when pressing power button in front andor remote on button..
Yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
Posted on Dec 04, 2009
  • 11,361 Answers
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 15, 2009
My olevia 242-s11 want turn on changed power supply and main board whats next
Two things, assuming you installed a working power supply and main board, check to make sure the kill switch is in the "On" position. If my memory serves me correctly, this set does have one. Are you sure you have a working outlet? power cord? When you say the set won't turn on , are you referring to the entire set or just the screen?
Jan 03, 2013 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
Mar 09, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia tv has no power
Check ur power source?Yes,tries tv unplug,replug back like an hour later,by letting tv resetting itself back to factory setting,see if u get power back?Same problems,than ur tv power supply board is the cause and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suuply board for the replacement.
Feb 12, 2011 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My Olevia 242TFHD will not turn on. The blue light goes off but the tv does not power on. If I unplug it and plug it back in the blue light will come back on but when I try to power it on it never turns on
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 08, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Tv will not turn on have power going to the unit
The power LED indicator light on the front of screen panel flashes?Mean the power supply board is dead,that the board where the power a/c cord go into it.Replaced the power supply board will solved this problems.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 02, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Power is not turning on seems the cord entering the tv is loose and power is not even getting to the tv
check first if the ac voltage working up to power section of the unit. if not trace if the line need to replace.
Apr 13, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia 42 inch Flat Panel has power supply issue... Blue light does not come on and tv does not turn on... I have tried all different things to get tv to work with no positive results
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Nov 04, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
947 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
