Question about Rancilio Silvia Espresso Machine
Water leaks I am going to repalce the group gasket. How do I get the old/cracked group gasket out? Your help is appreciated. Ian ihe@nrcan.gc.ca
  • Long Dragon Jan 09, 2008
    Thank you JetJedi221. Your information helps a lot.
    Ian
  • 25 Answers
If it's leaking already, you may have a tough time of it. For the Rancilio, you'll first have to remove the shower screen screw, shower screen and nozzle block (they all should come out together when the screw is out). Then you need to "carefully" pry the old one out. By carefully I mean try not to scratch or gouge the brass inner ring. You may have to chisel it out with a pick or screwdriver depending on how hard it has gotten. Make sure that you get all the pieces out, then polish the gap with a small wire brush. Install the new gasket evenly with the bevel (if it has one) up. Sometimes you can use the group handle to seat it all the way. Then replace the nozzle (after cleaning it), screen (should be a new one) and screw. Don't over-tighten it! Violin! You're done!
Posted on Jan 08, 2008
2003 dodge Durango 4.7l overheating. Water pump, thermostat, fans, radiator all in good working order. Only heats up at idle, stop and go, or heavy acceleration. Coasting, highway, and turning off a/c...
If your exhaust smokes white ,which is steam when engine is warm this is a tell tale sign that coolant is leaking into combustion chamber of engine. If you see high level of oil or foam on oil dip stick, this a sign coolant leaking into engine. Either circumstance would mean possible blown head/intake gasket or cracked head or cylinder crack.
You can also have cooling system pressure tested to verify leaking, it is a quick test which is not expensive to have done at a shop.
Jul 04, 2014 | Cars & Trucks
La Cimbali junior group head leak after restore
Group head leaks can be caused by group gasket, portafilter basket (cup), valve, pipe fittings. Call back your service tech.
* Check group gasket and position of portafiler handle when pulling shot. The handle needs to point directly at you (your chest) if it points to your left shoulder or pops off the group then the gasket is worn, not correct size, missing spacer.
* If the handle points to the right shoulder then the gasket is, too thick, too many spacers, or it was installed without removing the old coffee (crud) from the group head and is stuck under the gasket. Remove and check group gasket and spacers.
* If the handle points directly at you but portafilter still leaks then check the basket (cup) insert. Many Barista's smash the portafilter on a bumper. If the bumper is worn and the metal bar is exposed then the basket insert will have a flat or dented lip. Check all your inserts for damage and replace worn bumper (a piece of water hose cut to size works)
* Still leaking? Remove cup tray above group and check group head for leaks around the pipes and fittings. Note: water discharge from bottom of group valve is normal DURING the pulling of a shot. It should not continue to drip water after pulling the shot.
* Still leaking? The group head needs to be checked.
* Pump, water lines, Water by-pass, Economiser, Hot water wand, and all the water fittings.
Aloha, ukeboy57 (youtube)
Feb 18, 2013 | Espresso RMI La Cimbali Espresso Machine
Oil leaking into water
U newness antifreeze into oil ok bad head gasket if u repalced that already then possibly cracked head or block
Jan 04, 2012 | 1997 Chevrolet Lumina
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
Large puff of white smoke from tailpipe twice-still drives-have old oil leak. what caused smoke?
White smoke is indicative of a leaking head gasket or cracked head.
The liquid enters the combustion chamber and is ignited with the gas - and the exhaust is water vapors.
(unless you drove through a puddle that splashed watyer onto the exhaust)
The head gasket/cracked head is most evident on startup.
If your coolant level goes down with no visible leaks - your problem is internal (head gasket failure or cracked cylinder head).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | 2001 Mazda Millenia
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
Saeco Vienna Coffee Machine water leak
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Nov 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Energy Saver setting
Could not find a manual, but that setting is the setting that you choose to leave on and let the air conditioner decide the most effecient way to run during the day. There are too many ways to approach that answer in a small conversation. There are many things to consider and I will leave you with a link to a PDF that explains better of what I am writing. Sea Breeze
http://oee.nrcan.gc.ca/Publications/equipment/pdfs/ac-directory-2006.pdf
http://servicepartstec.blogspot.com/
Jun 08, 2008 | Maytag M7Q08F2ACOM Air Conditioner
Rancilio Silvia Espresso Machine Logo
133 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Marvin
Marvin
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
