My kenworth refrigerator (model 59671103101) does not stay cold on top. I cleaned the coils and the lights, fan and freezer works.
    President:
  • 1,922 Answers
You need to replace the main control board, but w/o a model number and make,( you mean it's a kenmore,not a kenworth) I can't give you a board number
Posted on Nov 14, 2009
My 1999 TX18 Amana Top Freezer/ Fridge won't get cold. I cleaned it, plugged it in. The light and fan work and it stayed cold for 4 days but it won't get cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Amana Refrigerators
Freezer works....fridge doesn't
Your refrigerator gets its cold air from the freezer by way of a fan that transfers air past the freezer coils to the refrigerator. If the fan isn't working the refrigerator will not get cold. I your coils in the freezer are freezing up this will also stop the flow of air to the refrigerator. The first thing to check is the fan.
Most refrigerator/ freezers are only controlled by one compressor (unless its a very expensive model). So if one is cold and the other isn't it's normally a simple problem.
First, check the temperature knob dials. Then check the seal using the dollar bill test or flash light test (described in link below).
You can also unplug the unit for at around twenty-four hours to clear blocked vents. Be sure to place some towels around the unit and prop all the doors open.
Defrosting your fridge should clear up any blockage in the duct as water and gunk often clog up the ducts. While you are at it clean the coils and the inside of your fridge and freezer.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Have kenmore refig model 59671103101 refrig temperature to low. light work, fans run freezer works good. Cleaned vents & coils ?
if the freezer is fine, check for air flow to fridge. if you get none, see if there is any frost on the back wall of the freezer. if there is some frost, the coils are iced up and need thawing. if there is no frost, there may be an obstruction in the vent. also may be thermostat in fridge- it opens and closes the vent from the freezer.
Nov 13, 2009 | Kenmore Refrigerators
Refrigerator won't stay cold but freezer works fine.
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
My kenmore frig is not staying cold in frig. or freezer
One of the most common problems with refrigerators and freezers is over time dust and lint can accumulate in the condenser coils try cleaning the coils CAREFULLY! with a vacuum. Unplug the unit before doing any cleaning . most units have a cardboard cover in the back, remove this to get at the coils . also check the fan(if there is one ) to see that it is not stuck.replace cover and plug unit back in.
check to see if fan is running and for air movement under the front door of unit. Keep in mind all models are different and these solutions are generic ones .Hope this helps.
Bobalix
Apr 18, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Electro Med Services...
