Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed recharging. the new battery pack will not take a full charge, but does charge... any Ideas on what is needed to have the battery pack charge...emf
  • 1 more comment
  • mike t Nov 14, 2009
    need to have a deep charge?
  • mike t Nov 15, 2009
    li-ion battery don't need as much emf(electromotive force)to force electrons to charge the battery pack as the NiMH battery does.
    Electricity is measured in volts , amps ans watts.
    volts is the pressure that is applied to have electron flow. Amps, is a measurement of the work being done,
    and watts is the amount of energy that is a combination of the volts and amps.
  • mike t May 11, 2010
  • 699 Answers
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Posted on Jan 05, 2010
Docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
May 27, 2010 | Logitech MX1000 Laser Cordless...
How can i open the mouse to put the two batteries in ?
Try this dude..Hope u will get the necessary help.
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Feb 26, 2010 | Targus Wireless Optical Notebook Mouse...
I cant open the mouse to get to the battery.
Hi
Please see the link it has a excellent guide
http://www.vk2k.com/Logitech-MX1000-Battery/
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | Logitech MX1000 Laser Cordless...
Im having difficulty in charging my mouse -my stand is plugged in -i've cleaned the contacts -i've reset several times and it still doesnt charge
Verify with a tester that the cradle is supplying power. If it is, the mouse rechargeable battery might be gone; if it's one of the models with common NiMh AAAA ("pencil thin") batteries inside, you can even replace them by yourself.
Jan 03, 2010 | Logitech MX1000 Laser Cordless...
How to replace batteries on logitech cordless mouse??
see http://www.vk2k.com/Logitech-MX1000-Battery/
HTH
Dec 08, 2009 | Logitech MX1000 Laser Cordless...
Wheres the compartment to change the battery its a logitech wireless mouse
@JSShears, this isn't a simple battery compartment. It requires that you remove the two rear glide pads, then peel back the label just to the left of "FCC" and just to the right of the crossed-out garbage can.
BEFORE you do this, realize that you may not be able to find a suitable lithium-ion battery that fits (and works) AND that you may not be able to adhere the label and glide pads to like-new condition.
The battery is custom for Logitech, labeled "L-LB2", specs are 3.7V, 1700mAh.
Since the unofficial "replacements" range from $30-40 plus shipping, to $10+shipping+soldering....it may be cheaper to buy a new mouse.
Nov 16, 2009 | Logitech MX1000 Laser Cordless...
How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
Nov 04, 2008 | Logitech Cordless Mouse
MX1000
wanda
Strange, I just left logitech page for MX 1000 Laser Cordless Mouse. All they sell is the AC Adapter. Thought that was odd.
Their not selling replacement batterys, just the AC adapter.
Click this link: http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11197300
If you scroll down to the bottom of the page & look to the right there is a toll free No# you can call.
Still find it strange that logitech sells the AC adapter & not the battery. Make you think your battery is good & the adapter is bad.
Good Luck & kind Regards.
& please vote.
Feb 24, 2008 | Logitech Cordless Mouse
Laser Mouse MX 1000 By logitech
Nov 04, 2007 | Logitech MX1000 Laser Cordless...
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
324 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
