Question about Motorola Mobility Hint QA30 Cell Phone
Backlight wont work - Motorola Hint
Backlight wont work settings are ok
Motorola hint cant hear when it rings and it doesn't vibrate either.
sounds like you have it set on silence, go into profile or settings and select normal
Jan 27, 2011 | Motorola Mobility Hint QA30 Cell Phone
My Motorola Hint stopped vibrating.
Try checking by shaking it to see if anything came loose.
Or
Check the phone settings and ring styles. Or adjsut the volume to vibrate
Dec 18, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
My keyboard wont work. The backlight works, but I can't text or call or anything!
I shut it off blew into the crack between the screen and the keyboard and turned it back on and the keyboard worked!
Nov 19, 2009 | Motorola Mobility Hint QA30 Cell Phone
Can i shut off the back light and or dim the
To change the backlight setting:
1.Press Menu/Ok >Settings >Display >Light Control > Backlight Control.
2.Select how long the backlight should stay on.(If you
choose Flip Open ,the backlight stays on as long as the
phone is open.)
3.Press Menu/Ok .
Thank you for using Fixya
Oct 08, 2009 | Motorola Mobility ic502 Cellular Phone
Hint wont work
Call your service provider ...
Oct 07, 2009 | Motorola Mobility Hint QA30 Cell Phone
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
Motorola Qa30 cell phone, the keyboard wont work
it will have to be sent to motorola for repair , may be under warrenty , may have water damage . ?
Sep 01, 2009 | Motorola Mobility Hint QA30 Cell Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Tv turned off and wont turn on
If there is no picture and not even a hint of backlighting, it sounds like the plasma panel itself may have gone bad.
Mar 07, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Motorola Mobility Hint QA30 Cell Phone Logo
105 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
