Question about MSI K9MM-V Motherboard
RAM is OK but motherboard send beep as RAM is not working so computer is not working.
    Brigadier General:
  • 10,406 Answers
One "beep" is NORMAL.
More than one beep, especially in a pattern (short, short, long)
indicate a problem: RAM, or video-card not correctly inserted.
Take the computer to a qualified technician for trouble-shooting.
Posted on Nov 14, 2009
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
I removed ram & started my desktop . there is no beep sound in desktop wso what is the issue
In most computers with beep codes, the single beep means that the computer is running without any critical errors. when there is a problem with the RAM, it will most likely tell you by sending out a series of drawn-out, repeating beeps.
I guess I'm not clear as to what the issue is, if you remove the RAM chips, then the computer will not work correctly. If you're willing to clarify, then inbox me a specific problem ,I will happily answer it for you.
Mar 23, 2011 | Intel Desktop Board D845BG (KD845BGPAK10)...
Computer turns on but will not beep or nothing shows on display.
1.On plug the Ram
2.Turn on the System without Ram
if you here Beep Sounds then problem with Ram.
3.Turn Off The system
Fit the same Ram Properly.
3.Turn On .
4.If not Ok,the Buy a New Ram and fit it properly.
Feb 12, 2010 | Gateway (4000274) Motherboard
DDR2 Ram allergic problem....
When using different kinds of RAM together in the same computer, there is a general rule that the Slowest Ram has to occupy the first slots (the ones closest to the CPU and usually numbered on the Motherboard)
This is possibly the cause of your ram error although they're both 400Mhz, just try re-arranging them.
I think the Ram Error Code is two long beeps and the video error is one long beep and three short beeps.
Also, watch the Ram counter when you first turn the computer on, or check the "My Computer" properties to see that all the RAM installed is recognized.
Jan 18, 2010 | Gigabyte GA-K8VM800M Motherboard
When stat thinkpad R50 beeps 2x and nothing
Two short beeps and no further activity mean you could have a motherboard problem or a memory (RAM) problem.
Reseat the RAM modules and reboot the laptop, if the laptop still doesn't work, remove the RAM module/s and insert them into a working laptop to test them, or take them to you friendly computer shop to have them tested.
If the RAM is OK then the fault is the motherboard. Replacing the motherboard may not be a cost effective solution.
May 14, 2009 | IBM ThinkPad T40 2373 Notebook
Computer won't start
try to reseat the hard drive and the ram also try to find if power is passing on or not please check the computer by opening the ram and then restarting the computer if beep then ok if no beep then mother board gone bad.
Mar 21, 2009 | Computers & Internet
No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Feb 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Motherboard live then 1 beep followed by 4 beeps then nothing.
The one beep is usually normal for most computers. Is your Video card seated correctly?
4 beeps Refresh error RAM is not refreshing correctly. Reset the refresh values in the BIOS or reset the BIOS.
Jan 14, 2009 | ASUS K8N-VM Motherboard
Monitor beeps when turned on no picture
disconnect signal cable if monitor show massage no signal check signal cable then monitor is ok then open cpu check whether dust is in ram then clean the dust and again fit the ram the problem will be solved if not then disconnect ram listen beep and if contineus beep comes then motherboard is ok if no beep then motherboard is faulty replace it
Nov 26, 2008 | NetTV DTV 34XR 34" CRT Monitor
Boot failure
samuel,
if you don't here ok beep or any error beep:
  1. First check out speaker is connected properly to motherboard.
  2. Remove all component from motherboard like HDD,FDD, RAM etc..
  3. Just put only processor to your board and power-up
  4. There must be a long beep for missing RAM, if not means you have problem in Motherboard or CPU. Try out another board and another CPU to find out which one is faulty.
  5. If you got missing RAM beep, then power-off and add RAM. Then power-up there must be ok beep (only one beep) or missing RAM beep. If missing RAM beep, then your RAM might be faulty try to clean the connection point with pencil earaser and try out again. If no success then try with another RAM.
I think this will help you.
Please post your feed-back. Or ask me if any question.....
Gud luck
Iqbal
Apr 21, 2008 | Computers & Internet
MSI K9MM-V Motherboard Logo
127 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
