Question about Car Audio & Video
I have got a vreg corsa with a stereo that hasnt got a display.could u please tell how to put the code in because the numbers only go to 6 on the stereo and in the code there is a 9 and 7 please help the stereo is called blaupunkt
  • 4,963 Answers
Find your Blaupunkt instructions on this free Code Entry website.
http://www.radio-code.co.uk/code-entry-help.php
The exact instructions will depend on the radio model.
If your display is NOT working and you have the CORRECT code then the usual method to enter the code "blind" is to ADD 1 to each digit.
So Code 1234   would be entered "blind" as 2345
A typical Blaupunkt with a separate display is the model CAR300
Below are the Code Entry Instructions for that model
(Don`t forget to ADD 1 if you are entering the code "blind".)
 INSTRUCTIONS TO ENTER A BLAUPUNKT CAR 300 (no display ) RADIO CODE
Switch the ignition key ON
Press and hold
AS button *  and the  ON button at the same time
Display Shows SAFE  then goes to 10 - - - - with a
"Beep" from the speaker
Press Preset Button "
1 "repeatedly until the 1st Digit of your Code is displayed
2" repeatedly until the 2nd Digit of your Code is displayed
3" repeatedly until the 3rd Digit of your code is displayed
4" repeatedly until the 4th Digit of your code is displayed
If the display  now shows the correct Code number then
Press  Button
AS  and hold to Enter and if successful  there should be a "Beep" from the speaker and the radio should switch on
Posted on Nov 14, 2009
I have the code for my car radio, but it has an 8 and a 9 in it, but my radio only got 6 numbers how do i put my 4 digit code in?
Using buttons 1- 4 press the relevant button the same number of times for that digit...for example your code might be 2789 press button 1 until it shows 2 in the display,button 2 until 7 is displayed and so forth until the correct code is displayed then press button 5 or 6 to enter code.failing that try a quick google search for the operating instructions for your stereo.
Nov 16, 2015 | Cars & Trucks
I have a corsa c with a broken stereo i have a second hand corsa c stereo but cant get it to work by swapping it straight over any clues
you need let dealership reset radio code or check owners manual it will some times tell you how to reset radio code.
Sep 20, 2013 | Opel Corsa Cars & Trucks
I have a problem with the code of the stereo honda element 2004
Usually the stereo code is needed for accessing any kind of function of the stereo.
If the radio code is not located in the owners manual there are other places that might have the code displayed.
Check the fuse panel inside cover or the sides of the glove box door.
(This is where I put the radios code sticker for when I am performing new vehicle deliveries)
A honda dealership would be the only option to make use of this problem.
What the Honda dealership does is find the stereo's serial number then the advisor is able to locate the radio's 4 - 6 digit code.
On some models the serial number is found by holding the #1 and #6 radio preset simultaneously, then hitting the power button.
At this point the radio's display should show the serial number and the radio code can be retrieved by the advisor.
Mar 03, 2013 | 2004 Honda Element
Stereo code for a 52 plate ford finesse car please
-------------------------------------------------------------------------------------- The radio SERIAL NUMBER is required for a code
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display your Serial Number Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
It usually begins with M++++++ or V++++++ ------------------------------------------------------------------------------------------------------
Jun 29, 2011 | Car Audio & Video
Need radio code for Chevy venture 2003
radioo
02-20-2006, 02:03 PM
Only a GM dealer can unlock the radio.
It is much smarter to disable lockout entirely, with MP3/WMA, DVD and XM-ready stereos, the regular CD, cassette, and radio-only units aren't so hot.
The following applies to an unlocked powered-on radio (2000 shown)
1. Do not disconnect the battery
2. Press the stereo's "1" and "4" buttons at the same time for five seconds with the ignition on and radio power off. he display will show "SEC", showing anti-theft is on
3. Press the MN button, the display will show "000"
4. Press the MN button until he last two numbers are the same as your secret code (how do you find this? you decide the code?)
5. Press HR until the first one or two numbers displayed match your code. The numbers will be displayed as entered.
6. Press "AM/FM", if the display shows "_ _ _ " you have disabled Theftlock, if "SEC" is shown, it is still in Theftlock
01-30-2010, 02:14 AM
I just tried this for my 1998 Chevy Venture and it works! press the 2 & 3 numbers at the same time for about 10 seconds; a 2 or 3 digit code will come up; press the am/fm button for about 10 seconds; another code will appear; dial 1-800-537-5140 and enter 106010 followed by the # sign; enter the 4 or 6 digit code from your radio followed by an *; the phone number will give you a 3 or 4 digit override code; enter this code into your radio just as your owners manual tells you to - use the hour and minute buttons to put in the unlock code, Press AM/FM button, "SEC"---" will display and You can turn on the radio. I had tried this with another dealer code and it wouldnt work, but with the 106010 dealer code it worked just fine, my unloc code was 0120
Jan 21, 2011 | Car Audio & Video
CD, Radio will not work, shows CODE on the screen
Yes this happens because the radio enters a security mode (anti theft) after you disconnect the battery terminals to it, I'm afraid you can not find that code on internet, you can either find it on your car's owner's manual or go to a Honda dealer ship and they'll provide you the security code for your car, not a big deal. Hope it helps and please rate the answer, as it helps me with my general ratings, thanks! P.S. comment if you need more advice
Mar 26, 2010 | 2004 Honda Element
Cambry 94 stereo code
that sounds like the number
Jan 31, 2009 | 1997 Toyota Camry
The unlock code for the 11712 audio unit is as follows:
6 4 0 7 0 2
A FixYa rating for my assistance would be greatly appreciated.
Dec 23, 2008 | 1994 Toyota Camry
Anti Theft Radio Code (Honda Odyssey 2004
You have the wrong stereo code. No Honda stereo code has a 0.Your local dealership parts dept. should be able to supply the stereo code given the VIN of the vehicle or serial number of the stereo.
Nov 13, 2008 | 2004 Honda Odyssey
Radio code
hi..i need to find the code for my 2004 acura tsx stereo .my battery died and when i turned it on it says code
i pushed the 1 and 6 at the same time and it gave me this #s u 1002 and L 0718 can u please help me
my email adress is nvrrntn@yahoo.com
thanks in advance
Aug 03, 2008 | 2004 Acura TL
Car Audio & Video Logo
499 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
