Question about Cooler Master ooler Master
1993 chevy lumina trouble with cooling system, the water pump bye pass keeps blowing although it's been in long intervals say six months.could this be something as simple as thermastat theres alot of pressure but engine really doesnt get hot, and blows the bye pass?thanks todd ( iv'e flushed, and repaired gasket at bye pass, water pump seems fine. coolant filled to specs , thanks alot for your time.
  • 86 Answers
If you have any oil getting on hose that could cause premature failure and are you using a factory hose or maybe a hose for gas or oil rated hose
Posted on Nov 14, 2009
Oil system pictureoil filtur keeps blowing of oil pruser
Likey oil pump bye pass valve stuck allowing the oil pressure to go too high.
May 13, 2014 | 2000 Chevrolet Blazer
Chevy lumina overheat
engines overheat with no thermostats. Very simply put the water circulation is too fast for the heat to transfer to the air. Water pumps fail from bad bearings and pump seal but for no other reason. So back to basics Refit with a new thermostat put in properly. Have a flow test done on the radiator for blocked cores. have a coolant system pressure test done for leaks and cap failure.. have a compression test done to check for head gasket or cracks.. Check for correct ignition timing and air/ fuel ratio mixture. Run fault codes . when refilling with coolant ensure that all air locks are removed
Dec 29, 2013 | Cars & Trucks
Started my 1993 chevy lumina/serpentine belt broke now leaking water any suggestions
che your water pump when the belt broke it may of cracked the water pump
Jan 24, 2013 | 1993 Chevrolet Lumina
Water not going in moter ,white smoke blowing from rhe tail pipe
Hi, If water is Not going your cooling system, check : - cooling liquid level ( it should in normal level) - air lock in your cooling system ( You can run your ca for minutes then top up liquid to disable this problem) - water pump ( it should working normal and has no leaks on its seal)
White smoke blowing, please check : - Valve seals for leaks - Oil seals for leaks - Compression on your combustion chamber
You will need a basic knowledge of car system to do above tasks.
Dec 04, 2010 | 1995 Chevrolet Lumina
Hello, Can you help me? I have a 1993 Chevy Lumina that is overheating when I stop ex. long traffic lights, letting it run while I go to the mac machine etc... once I start driving again its fine. Can you...
Sounds like the cooling fan is not coming on .. could be a bad fan motor or relay .. If you can check it yourself you can try to power the fan up directly and see if that is the problem.
Jul 29, 2010 | 1993 Chevrolet Lumina
Lumina apv window latch part
Have a Chevy Dealerships parts department run the PART NUMBER on their LOCATOR SYSTEM.
I know it is a discontinued item although a lot of Chevy Dealerships keeps their old parts to sell this way nationwide
Mar 17, 2010 | 1992 Chevrolet Lumina APV
1993 lumina stalling
Free things to try: Take it to Auto Zone or some auto parts store and they can check the battery, alternator, and hook the thing to their computer to look for trouble codes for you.
Things you have to pay for: Take it to the auto shop and have them check the timing, spark plugs, and they can translate the trouble codes into language you understand.
Feb 25, 2010 | 1993 Chevrolet Lumina
Need to replace water pump on a1997 chevy lumina 3.1L V6 need insructions
3.1L And 3.4L (VIN E) Engines
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Please see Section 1.
  6. Remove the water pump pulley bolts and remove the pulley.
  7. Remove the water pump bolts and separate the pump from the engine front cover.
To install:
Exploded view of the water pump and front cover arrangement—3.1L and 3.4L (VIN E) engines
  1. Clean all parts well. Use care when scraping gasket material from the front cover and the pump. Do not gouge aluminum parts. Clean the bolt threads well. The torque specification is low and if the bolt threads are dirty, an accurate torque is not possible and leaks are likely to develop.
  2. Using a new gasket, install the water pump to the front cover. Install the cleaned and lightly lubricated water pump bolts. Torque to 89 inch lbs. (10 Nm).
  3. Install the water pump pulley and bolts and torque to 18 ft. lbs. (25 Nm).
  4. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOL® and water. Check for leaks.
Oct 13, 2009 | 1997 Chevrolet Lumina
Radiator Cooling fans pull or push air (93 Chevy Lumina 3.1 L) ?
A radiator fan is designed to pull air to pull air through the radiator to help cool it, while blowing the air on back across the engine to try to assist once again at keeping the unit running cool as to not over heat.
Apr 14, 2009 | 1993 Chevrolet Lumina APV
Problem with No Heat on 2005 Chevy Avalanche - Cooling System?
it is most likey a sticking thermostat it either gets stuck closed or open in your case closed so collant isnt getting to the heater core and all you get is cold air blowing into the truck.
its a simple fix you can either do it your self or take it to a mechanic. now remember there are differnt thermostes so think about the climat you live in and get one according to that
Jan 07, 2009 | 2005 Chevrolet Avalanche
Computers & Internet Logo
181 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Avishek Samaddar
Avishek Samaddar
Jay Plesset
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
