Question about HP Pavilion a330 PC Desktop
After instaling a new power pack i have no sound
    Sergeant:
  • 267 Answers
Reinstall sound driver.
Posted on Nov 14, 2009
Will my new LED malibu lights work with with my ML200RT transformer? They use considerably less wattage than my old bulb type lamps.
Malibu puts out 12 Volt AC without specifying type of bulb
If new bulbs work on 12 Volt AC, then they should work
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Wattage on bulbs should match power pack wattage, or damage can occur to power pack.
Buy new power pack, call Intermatic, or Try it out and see if it works
Sep 05, 2014 | Hardware & Accessories
Need schematic of Malibu ML-900tw
There is not internal schematic of the Malibu ML900 series power pack... you could take one apart and post the information on your website.
If you want basic tips for installing ML900 series power pack, the following link has detailed information and tips to help do-it-yourself folks...
Correct installation will ensure power pack lasts longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Water Heater Timers Save Money
Jul 10, 2014 | Malibu ML900TW 900 watt Power Pack Timer...
Power pack doesnt work and is under warranty how do I get a new power pack?
'Harry' wrote me Nov 2010 and said his power pack has 5 year warranty and quit after 4 years.
He said he was 'in negotiations' with Malibulights.com
http://malibulights.com/home.aspx
http://malibulights.com/customer_service.aspx
I asked him to let me know what happens, but no report yet.
Same for you please: Add a comment and let me know what Malibu says so information is available for all Malibu owners and fixya supporters.
'Harry' also gave me a tip.
He said Malibu timer stopped working on his power pack, so he bought ordinary plug-in timer, and set Malibu override to ON, and plugged power pack into timer.
While researching Malibu problems, I assembled some power pack tips.
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Dec 13, 2010 | Intermatic Malibu 121W Power Pack...
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
Nov 22, 2010 | Intermatic Malibu 300W Power Pack...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
The timer feature of my Malibu 300 watt power pack just stopped working. The lights can still be turned on/off manually. Anything I can do other than buy a new one?
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
Nov 12, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
The transformer will work if I manually turn the dial. The dial will not automatically turn anymore.
If the bulbs turn on when you manually rotate dial, then the power pack has electricity.
A lot of people ask for replacement Malibu tripper pins on Fixya, and it sounds like your trippers are working fine.
If clock has stopped rotating, that means the power pack has malfunctioned, and needs to be replaced.
Nov 11, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
My Acer keeps loosing power
hmm...sounds like you are suffering from a dirty power issue. how old is your house?
Mar 11, 2008 | Acer TravelMate 2300 Notebook
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
HP Pavilion a330  PC Desktop Logo
19 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
