Unfortunetly the only repair for that issue is to replace the complete seat belt mechanism. Basically the internal winding mechanism has gone out and will not retract the seat belt.
The way I solved my problem with the airbag indicator light is: I took the passenger side seat belt at full retraction and slowly pulled it out until it reached the stop several times and each time allowing the seat belt to fully retract to its normal position. Apparently there are foreign debris (dust, lint, loose hair, etc.) that is interferring with the sensor response and triggering the indicator to come on. All the seat belts in the vehicle (no matter what brand) should be exercised/cleaned periodically to eliminate this problem. Also, as you pull the seat belts out until it reaches its stop to wipe with a lint free cloth as it extends and retracts. Keep in mind that it could be another kind of problem. This solution has worked for me several times.
The front seatblet retractor springs have weakened. Unfortunatly, there are no "user serviceable parts" on them. They would have to be replaced. How many miles is on it? If you have low mileage, the Toyota Customer Experience Center may provide you some assistance, as the belt replacements are quite expensive. I'd call the CEC and explain your dilemma. Here is the number: 1-800-331-4331
There may be a small object like a coin in the re-tractor, pull the re-tractor and check, if nothing is found you will have to replace the belt assy, they are not repairable.
