Question about Plumbing
We had to replace our hot water tank, we did this
We had to replace our hot water tank, so we got someone in to do it. when we turned it all back on we had no hot water but we had heating, we have tried to call the guy in question but without luck. We then thought we had an airlock so drained the whole system, tank and radiators and then tried to refill everything. The water tank re filled but the radiators wont. Some of the down stairs radiators make a few clinking noises but thats it. The hot water is run on a back boiler system ( its a very old house) and when we turn the water and heating system on, the pump down in the cellar makes a loud buzzing noise, as though it is working overtime. The pipes which are feeding water to the pump are hot but the ones after it are cold. I have tried turning a couple of the valves but nothing seems to happen and to be hnest i ahve no idea what i am doig. We still dont have any hot water or heating!!!!
  • 44 Answers
Try opening the bleeders on your radiators,one at a time starting at the one closest to the pump until all air has been expelled then close bleeder and move on to the radiator next furthest from the pump and so on.if hot water doesn't come out from the first radiator within a short time, or if you cannot hear air being forced out thru bleeder you prolly have a defective pump; have it checked/replaced by a reputable pro..my guess is that the "buzzing noise" is because the pump is defective and the electricity has no place to go.an easy preliminary check for this is to feel the pump motor while buzzing to see if it is hot, if ti is it prolly is bad
Posted on Nov 14, 2009
My water heater has a leak only when it is turned on.
it could be a leak around an element if it is an electric heater.
Jun 04, 2014 | Suburban Direct Spark and Electric Water...
Adjust water temperature
It is possible that there is an open valve on the back of the water heater which is allowing the hot and cold to mix. Locate the back of the water heater. You will see a water line going into the bottom of the water heater. That is cold water in and there will be a valve on that line. It should be open (The handle inline with the direction of the pipe). At the tope there will be another pipe coming out. That is the hot water out. It may or may not have a valve but if it does make sure that it is open. Then there will be a water line connecting the top and bottom water lines and it will have a valve in it. Make sure that the valve in this line is closed. That is a winterizing bypass valve. If this does not correct the problem let me know and I will give you more steps to consider.
Apr 07, 2014 | Heartland 2013 North Trail NT 24RBS
No hot water flow through faucets
At the back of the water heater there will be a series of valves. One on the bottom, sometimes one on the top and then one in a line that connects the top to the bottom lines. Make sure the middle valve is closed and the top and bottom valves are open. If there is not a valve on the top that can be manually opened and closed then there is a check valve installed. This check valve will allow the hot water out of the tank but will prevent the back flow of cold water during the winterization bypass. If the valve on top is closed it will not allow hot water out. If the middle valve is opened it will allow the cold water to mix with hot water and defeat the purpose having a water heater. Close the middle open the top and bottom. If there is not one on top then the check valve is probably clogged or has failed and need to be cleaned or replaced.
Mar 08, 2014 | Open Range 2013 Residential R398RLS
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
Bought a hot water heater made by whirlpool for 2 weeks only had enough hot water to fill 1/4 of the tub then the water turned cold . They have replaced the hot water heater and still has same problem....
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Mar 13, 2011 | Whirlpool Home
Water heater does not produce as much hot water as it use to. Could it be, that one of the heating coils is out. If so is ther a reset switch? Before I have someone check the coils.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 3rd and 4th digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects.
1) TP valve is running hot water out of tank, or leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Dec 05, 2010 | Water Heaters
No hot water
more than likely tripped the high temp switch. This is made as part of the upper thermostat, replace the thermostat and it should start making hot water.
Mar 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Elec. hot water heater
thanks for your question, sounds to me like you have a burned out bottom element in the tank, depending on how old the tank is, the amount of calcium in the tank, will determine if you should repair or replace, if your tank is fairly new, then you will first have to shut the power off to the tank, turn the water off at the shut off, drain the tank, write down the model #, the serial #, what brand, and the ratings on the lower element too, go to the hardware store, buy a new element and element wrench, return home, write down which wire goes where on the element, very important ! remove wiring, remove element, that's the hard part most of the time, install the new element, rewire, close all panels, refill tank, do not turn the tank on before filling !! then after tank is full, turn power back on, you will have to wait about an hour for hot water, if the unit looks to old, then replace it. I would say anything over ten years is worth replacing, hope that helped ya, thanks again for your question, let us know what happens, mr.grzz
Jan 12, 2009 | Water Heaters
Plumbing Logo
132 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
