Question about Epson Stylus Color 740 InkJet Printer
Install new cartridge will not print smudges only
  • 1,218 Answers
A printer will smudge ink when the printer heads are dirty. To resolve this, you need to take out the printer cartridges and clean off the dirt by rubbing alcohol on the printer head using a Q-tip.
http://www.fixya.com/support/t3925086-black_ink_smudges_bottom_corners
Posted on Oct 08, 2010
    Master:
  • Epson Master
  • 956 Answers
Hi, you have to carryout a fault finding sequence. Access printers, right click on printer icon (Default) menu/click properties/setup. if not lists there/look on the menu for checking/repairs/.
Posted on Nov 14, 2009
Smudge back of paper and will not print in color
User genuine print cartridge to avoid this types of issues.
>> Remove the print cartridge and gently clean it.
>> Check the smudge in paper feed area.
>> Clean the carriage.
>> reinsert the print cartridges
Try to print.
Dec 17, 2013 | HP Color LaserJet 3600
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Smudging when printing photos, but not colour textprinting
(1) Most photopaper is made to be printed on one side only. Check to see that you are printing on the correct side. (2) You mention new cartridges. Are they the same brand as cartridges you've used before? If they're a different brand, you may want to try whatever worked before.
Jun 11, 2009 | Canon PIXMA iP2000 InkJet Printer
Changed cartrige, now have smudge lines on paper
please check the cartridge and see if it is the recommended one the printer..
if it is .... remove it ,clean the print mouth, re fix it and try printing...
sometimes refilled cartridges also give the same problem. please check that too.
May 26, 2009 | HP LaserJet 1020 Printer
Print out is dirty, there are smudges of inks at the page center
What colour are the smudges, if they are one colour you can try changing that colour toner cartridges. Failing this then it sounds as if you may need a new drum
Dec 09, 2008 | HP LaserJet 2550L Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Print is Smudged
you may try
1) clean the cartridge nozzles with dry soft paper
2) clean the cartridge carriage down side surface there might be bled ink.
3) check the cartridge up side there is the lable cover the ink refill hole is ok, no any lable stick there you need put stick lable there.
Nov 12, 2008 | HP PSC 1600 InkJet Printer
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Epson Stylus Color 740 InkJet Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
