Question about Microsoft Comfort Optical Mouse 3000 (1-Pack) (VVSC393731)
Magnification function Can you turn off that magnification function
    Brigadier General:
  • 10,406 Answers
With one hand, press down on the mouse to hold it VERY still.
Then, with the other hand, while not allowing the mouse to move,
click the button on the right-hand edge of the mouse.
Then, run the software that came on a CD-ROM with the mouse to "disable" that specific mouse-button.
Posted on Nov 14, 2009
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
Center Web Page on screen
You have to turn off screen magnification as you are zooming in on the page...or scroll...
Jan 01, 2013 | Office Equipment & Supplies
Iphone3gs. every screen magnifies,so i can only see three apps across the screen,also I can see either the signal and battery icons or the dial,message icons at the bottom, not both, due to the...
To zoom out to normal screen size, tap on the screen using 3 fingers at the same time
To turn off that magnification feature, go to Settings>General>Accessibility> Turn OFF Zoom or any of the other stuff in there if you don't need it.
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Apr 27, 2011 | Apple iPhone 3G
The stereo eyepieces are dark, nothing to see. The trinocular eyepiece upwards give light. What shall I do to see the specimen in the stereo eyepieces? (I know only a little of english language,) I...
It might be that Objective lens is not seated properly or very dirty. So perhaps by rotating the objective block may help before trying to clean it. Also try to start with the lowest magnification to see that you have functional microscope before trying higher magnifications. Good luck.
Mar 21, 2011 | Nikon Science & Laboratory
How do I increase the field of view on a zeiss OpMi-1?
Field of view and working distance vs magnification is a law of physics. Using the lowest power gives you the widest field of view and greatest working distance but the trade of is that you loose magnification. Conversely as you increase magnification you decrease working distance and you loose field of view diameter.
The optics of your microscope are limited to .4x to 2.5x magnification. Your working distance is limited to 200 - 400mm depending on the magnification you are using.
I am not aware of any interchangeable lenses for this scope.
Nov 28, 2010 | Zeiss Microscope
I am able to see with the 20m Lens but once i insert the 5mm Lens it looses focus and i cannot see anything, i tried adjusting the focus again with no success. The worst thing that even at day light i...
That's because the 5 mm is too much magnification for your small telescope. Maximum magnification is a function of APERTURE. Which is how big is the front lens or the mirror.
Your scope has about a 2 inch aperture, so the maximum posiible magnification is about 100 power (if it is like the one in the picture above)
50 times aperture (2 inches)-- 100 power
It will only achieve 50 times if the optics are perfect and the sky is very transparent and stable. Usually only 30-40 times is all you normally get.
Nov 21, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Loss of focus when izoom in
This typically means that you are have exceeded the scopes ability to focus at the distance that you are shooting. This scope is optimized for 50 yards and will function well at all magnification settings. Closer than this optimal distance the higher magnifications may present problems with blurring. Many scopes have a "parallax" adjustment that changes the optical focus to correct this problem. Several of my 22 mag scopes have this adjustment on the objective bell. You simply set the indicator line on the appropriate yardage indicator (making minor adjustments to fine tune focus). Hope this helps
Sep 16, 2010 | Simmons 22 Mag 39X32 with Rings
How come when I look at a planet or star throught the super 4 eye piece, it is hard to get the focus sharp enough to even see the object clearly. Especially when Im turning the focus knob which moves the...
Hand controllers do NOT like cold weather. It's just a function of the LED lights. Put the hand controller in your pocket to keep it warmer than the outside temperature.
Your scope has a maximum magnification of about 40 times aperture. So about 200 power. If you exceed this the image just starts to degrade -- it gets bigger BUT fuzzier.
Stay with lower magnification eyepieces. Certainly above about 10-12mm...... You will get better views using eyepieces from 15-22mm, and you need one wide field low magnification eyepiece of about 30-32mm.
Dec 29, 2009 | Bushnell NorthStar Goto 100mm 788840...
Magnifer button on cant get it off
To turn off Magnifier, in the Magnifier Settings dialog box, press ALT+X.
Dec 16, 2008 | Acer 90.46907.001 Keyboard
Microsoft Comfort Optical Mouse 3000 (1-Pack) (VVSC393731) Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
